AVS › AVS Forum › HDTV › Local HDTV Info and Reception › South Bend, IN - HDTV
South Bend, IN - HDTV - Page 10
post #271 of 3739
Originally Posted by donrb5 View Post
ABC on Comcast was in HD for the Superbowl but not since. Anybody else have this problem?
I noticed the exact same phenomenon last night when I tuned into watch Lost. WTF? Maybe they got permission to "test" all that HD equipment for half a day, because all their pregame stuff was in HD also. At least the game looked awesome.
post #272 of 3739
donrb5
Yes, same problem. Was your Superbowl in surround sound?
post #273 of 3739
Wasn't in Dolby Digital. My audio receiver was only getting a 2.1 signal from comcast, although the receivers built in decoder did a decent job converting to DPLII.
post #274 of 3739
No, it was not.
post #275 of 3739
Not Dolby Digital
post #276 of 3739
I believe ABC (and ESPN-HD) don't pay Dolby Labs for their surround sound system; they use "Circle Surround" from SRS Labs. Unfortunately, the number of home AV receivers that know how to decode CS is not very large (mine won't even do DTS, let alone CS).
post #277 of 3739
Anybody know what happened to FOX HD - they were AWOL last night
Fred
post #278 of 3739
I remember seeing the movie Legally Blonde in HD format yesterday.
post #279 of 3739
The superbowl looked great but why are the prime time shows not coming in on HD? Anyone else having problems
post #280 of 3739
Yeah, same here. No HD on ABC or WB on cable since the Super Bowl.
Al
post #281 of 3739
I asked the same question on 2/9. What gives?
post #282 of 3739
I'm still not receiving OTA HD signal from Fox (28.1) and its been nearly a week now. Anybody know what happened? Is anyone receiving FoxHD OTA?
Fred
post #283 of 3739
28.1 has been fine for me. I watched House & 24 last night.
post #284 of 3739
Are you getting it OTA or from cable?
Fred
post #285 of 3739
OTA...Idol was fine tonight as well.
post #286 of 3739
I was receiving 28.1 with no problem up until about a week ago. Now I don't get anything and signal meter shows no signal. I still get 16.1, 22.1, 34.1 with full strength signal.
Anyone have any ideas why my Tosh 37HL95 won't receive 28.1 now?
Fred
post #287 of 3739
I'm getting it on 2 different boxes, so I'd have to say it's something with your receiver.
post #288 of 3739
Got a message from TVMicrowave2002. Major glitches going on with their new equipment. They are sorting it out, but one of the problems is that it won't let them pass HD to you. He's been too busy to post here, concentrating instead to fixing the problems. When I say busy, his email discussions with me are brief and spelling is occasionally munged as he types at 200 MPH!
They have to get these problems knocked off in the next few weeks for other reasons, so pretty much every ounce of Weigel energy is devoted right now to getting the SD problems fixed, which would then help take care of the HD problems.
post #289 of 3739
Fred
Just like computers, sometimes they simply need to be rebooted. I'd suggest you unplug your receiver, wait a minute or two, and then plug it in again. Now try entering the channel number or let the receiver perform a new channel scan. Hopefully this will restore WSJV-DT 28.1.
Steve
post #290 of 3739
My tuner is built into the TV. I've tried rescanning channels and also entering the channel number directly but no luck, but haven't tried just unplugging the tv yet.
Fred
post #291 of 3739
Don't forget that 28.1 is really being broadcast on UHF channel 58 (734-740 MHz). Moisture might have gotten into your outside F Connectors that could cause degradation at this high of a frequency. If you have an inside antenna, then that might be a different problem. Try looking at NTSC Channel 28 and see if there is any ghosting and try to adjust the antenna to minimize the interference.
Right now I'm seeing 85-90% for 28.1 on my Dish 811. WSJV-DT is out there.
BTW, how do you like your 37HL95? A guy at work had a Lemon-Law 34HF83 and was able to talk BB into replacing his set with the 37HL95 (a nice swap!) for just $200.
post #292 of 3739
As Steve suggested, it turned out I had to "reboot" the TV which sets everything back to factory defaults. Fox HD was back after doing the channel scan. Only downside is I had to redo all the configuration changes I made and it will take several days before the tv guide is fully loaded again.
I'm quite pleased with the set, although I like the PQ of the Sony 34XBR960 CRT set better, but I wanted a larger screen and I didn't want to wrestle with the 200lb Sony for installation.
I spent a lot of hours tweaking the custom settings before I got a picture that I liked for both HD and SD content (SD looked absolutely horrible with the factory settings). Like all LCD's black level could be a bit better and it takes very careful adjustment to get a decent black but still have detail in it. That said, 34.1 looks absolutely stunning on this set - there are times when it feels like I'm in Europe with Rudy Maxa.
Your friend "stole" the set for 200 plus the cost of a 34HF83 - what a deal !!! I think he'll really like the set.
post #293 of 3739
Originally Posted by Foxbat View Post
I just read this in the SBT this morning. It depends if WSBT gets the new CW network. WMWB could be used for WBND-DT. That's our only hope for ABC-HD folks. If WSBT loses out to Weigel, the only advantage we might see would be better CBS-HD since WSBT-DT wouldn't have a need for 22-2. But we wouldn't see ABC-HD for years under that scenario.
The best case scenario would be for Weigel to get the CW network. As long as UPN/CW is a "secondary" signal on 21.2 we will not be seeing those shows in HD. As noted later there is another hope for an ABC in HD (the May filing window) with the CW on 25 we could end up with all six major networks OTA in HD in the fall.
JL
post #294 of 3739
bruegf: Do you have different settings for your different inputs? Would you mind posting what you have?
post #295 of 3739
I'm currently using the following:
Contrast - 53
Brightness - 69
Color - 50
Tint - 0
Sharpness - 40
Dynamic Contrast - On
Mpeg NR - Low
DNR - Off
Color Temp - Cool
Backlight - 55
post #296 of 3739
The Elkhart Truth reported yesterday that WMWB 25 would be a CW affiliate.
Al
post #297 of 3739
In the section with the channel listings, the Comcast website says HDTV is available with basic cable service with the HDTV converter box. In another location it says the digital cable is req'd to receive HDTV. Does anyone know which is correct?
Also, please confirm that Fox HDTV is available via Comcast. The 12/15/05 published channel lineup does not show Fox but does show ABC which I keep reading is only available sporadically.
post #298 of 3739
Don't bother with the comcast website. FOX HD is on 190. They didn't even bother to let anyone know. With my last bill I did get a channel line up that actually lists 187 as ABC HD but we all know that it is ABC but not HD.
post #299 of 3739
You can get a Digital Cable box for HD via Comcast even on the $14 Basic Cable Package for an additional $5. HD local Lineup
187 - ABC - Digital but not HD yet
188 - NBC - Digital and HD
189 - CBS - Digital and HD
190 - FOX - Digital and HD
191 - PBS - Digital and HD
192 - WB - Digital but not HD yet
post #300 of 3739
If you want the extra HD channels like ESPNHD, TNTHD, etc. you need to sub to the digital cable. You are supposed to get the local HDs with any level of cable service and a HD box.
Al
