AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Fresno, CA - HDTV
Fresno, CA - HDTV - Page 50
post #1471 of 1712
Is anyone else having QAM issues??? Im starting to have issues where I have to tune an anagloe ch before a QAM channel for the tuner to be able to find it (TV and tuner cards).. Its to the point I cant record anything QAM on the HTPC
post #1472 of 1712
I have no problems with QAM here.
Is it a specific channel causing problems or is it everything on QAM?
post #1473 of 1712
anytime I tune to a QAM channel, I have to tune to an analog channel first.. My equipment hasen't changed (Hauppauge HVR-1600 and HVR-1800 in the HTPC and Olevia TV)....
post #1474 of 1712
Greetings Fresno people! Just got an HDTV, currently have comcast digital cable but I plan on upgrading to their HD plan.
It's $10 extra per month right? Do they provide any component or HDMI cables with the new cable box, or nothing?
post #1475 of 1712
I believe they will just supply you with component cables, which are good for up to 1080i. But don't quote me.
post #1476 of 1712
You will want the HD DVR box and yes they do provide quality component cables. HDMI is better and they are not expensive.
post #1477 of 1712
KFSN just said they're going to do a "digital test" on Wed. Dec. 17 at 7pm. I didn't catch what exactly the test is going to do.
post #1478 of 1712
They’ll cut off analog transmission for 5 minutes. As I understand it, this is intended to shake up the unconverted and prompt them to get moving.
post #1479 of 1712
I wonder if it will affect the analog cable channel as well. If it will, there are going to be a lot of confused Comcast customers.
We'll have to wait until tomorrow to see...
post #1480 of 1712
If you've missed it:
KSEE, KFRE, KMPH, and I think KGPE joined in on the 5-minute analog blackout. KSEE is doing a DTV info special while the rest is back to normal.
Their analog cable and digital SD channels had the "You're not ready!" warning screens. Only KFSN said not to worry if the user had cable or satellite. The digital HD channels either had a ticker or a screen saying "You're ready for DTV".
post #1481 of 1712
Darn, I missed out on seeing this.
Nice to hear they're doing tests though.
I hope OTA reception for 26 and 30 increases as we reach February.
post #1482 of 1712
Anyone know what is up with KSEE-24 digital? It has been off the air for a few days now.
post #1483 of 1712
No problems here, but our set ‘lost’ 45-DT the other day until I punched in 55 to remind the tuner about what it was supposed to remember. We ‘lost’ 17-DT a while back the same way.
post #1484 of 1712
I see 24dt is back on the air.
post #1485 of 1712
Originally Posted by richeydog View Post
What do you mean by minimalized?
Leave the HD output at 1080i. You do not have to change this at all.
If you want your SD channels to fill the screen you have to go into the menu and fool around with 4:3 Override.
The options are:
1) Off---This will keep the SD channels in 4:3 format. Options 2,3, and 4 will fill the screen. Experiment to see what you like best.
2) 480i
3) 480p
4) Stretch---This seems to work best for me. When I switch from an HD channel to an SD channel(or vice versa) there is no delay/weird breakup that seems to show up with options 2 and 3.
Even if my TV is only 720p, should I still leave the HD output at 1080i?
By the way, I went down to Comcast today to switch my old cable box for an HD one... and man they are rude! AND the lady tried to give me RCA cables and tell me they're component. "Umm, ma'am, I'm pretty sure component are the green, blue, red ones." After all that, they gave me an outdated box with no HDMI output. I asked for an HDMI box and they said they're all out and only get around 5 boxes in stock per week. They said if I want one the only option is to drive way out to their location (by the airport) some other day and stand in line to see if they have any. Friggin' ridiculous!
post #1486 of 1712
That's one of the reasons why I went with DishNetwork!
post #1487 of 1712
What's dish network's HD lineup look like in comparison?
post #1488 of 1712
And how can we find out when Comcast will be adding new HD channels in Fresno?
I'm waiting for Cartoon Network HD, Comedy Central HD, and TBS HD especially.
post #1489 of 1712
Good news. I was having a problem with my box not correctly setting the time (it would always read 12:00). So Comcast sent out a technician, who just happened to have a brand spankin' new Motorola box with HDMI in his truck. I am now a very happy camper!
post #1490 of 1712
Well taking a look at antennaweb today showed 30.1 moving from red to yellow for me on February 17 here in the Sunnyside area. So I assume they are going to get better.
Anyone with Dish Network have any idea when we will get HD locals? I am going to start looking into an outdoor antenna and I will hold off if they are coming sometime in the next decade. (Honestly, I am real close to dropping Dish all together and going straight OTA again.)
post #1491 of 1712
I'm having the same problem with KFSN's digital signal as well. I live in Southeast Fresno, near Peach and Olive and can't seem to get KFSN and KAIL digital signal as much as I try. I don't want to miss Lost and Smackdown come February. However, I can receive KSEE, KMPH, KFRE constantly and occasionally get KGPE. Maybe it's because the KSEE and KMPH stations are both located a couple of miles away from my home. I'm using a RadioShack 15-1878 antenna btw.
post #1492 of 1712
Well it seems KFSN's digital signal strength will increase come February. So hopefully you'll be able to get it!
Btw, anyone else notice how bad KFSN's HD field cameras look when they're doing live satellite stuff? When they cut back and forth from in-studio it's really noticeable and looks baaaad.
post #1493 of 1712
I wish I knew when DishNet was going to get local HD. But as long as I have my locals OTA I am not to worried about it.
When I was doing the reasearch before I decided on DishNet, I looked at Comcast (who I have for internet), Directtv, and DishNet. At that time DishNet flat out had more HD programing than any of them, which is why I chose DishNet. Now I don't know, but I think that I am going to stay with them mostly due to their award winning DVR, I have the ViP622 and most likely will upgrade to the 722 soon.
As far as OTA stations, I currently am using an antenna that i got from Monoprice, and I am receiving all of the stations, plus ones that I don't care to watch. I live out in Reedley, and this antenna is both UHF and VHF and cost much less than $40. The only station that I get random is the CW which I do not watch often. Oh, I have it up on the roof. OTA HDTV looks awesome! Followed by the good DishNet HD channels.
post #1494 of 1712
I live just down the street from you at Fowler and Kings Canyon. I was using an amplified indoor antenna and needed to have it out in the middle of the room to get good reception. Then a forum member suggested I use a non-amplified antenna, and the reception is rather good putting it in a more unobtrusive spot. I get over 70 signal on KVPT, KMPH, KSEE, and KGPE. For KFSN I seem to get around 58. (which is just enough to hold a signal). So if you have an antenna without an amplifier lying around, it may be worth it to try it. Even if you don't it looks like in a month and a half KFSN will be better anyway.
Wesley, which antenna are you using? And what is the difference between the 622 and the 722? The only reason I am contemplating leaving Dish is the impending price increase. I think all pay TV is getting a little too pricey considering the online alternatives.
post #1495 of 1712
This is for you OTA types. Over the last few weeks, I've been seeing a big increase in dropouts on channel 18-DT. I'll see the signal drop from 100% to 0% in the blink of an eye, then back. It's become so bad we sometimes drop to analog just for the relief.
Anyone else?
post #1496 of 1712
[/quote]Wesley, which antenna are you using? And what is the difference between the 622 and the 722? The only reason I am contemplating leaving Dish is the impending price increase. I think all pay TV is getting a little too pricey considering the online alternatives.[/quote]
It is the white indoor/outdoor antenna from Monoprice (HDA-5700) it sells for $24. The difference from the 622 to the 722 is the amount of recordable hours they have. The 722 has more storage and is black instead of the silver.
post #1497 of 1712
For what it's worth, I am in rural Clovis (east) and have a Silver Sensor under the eaves pointed due east. I am picking up most everything there is (or worth it) with very good signal strength.
I have Dish and waiting for HD locals, but the newer 722k receiver with additional OTA tuner input may do the job quite nicely..waiting for it. so I can record 2 locals in HD at once.
On the other issues, I've noticed the audio dropouts.. KGPE seems the worse.. and are they also the one who never has digital audio, it seems my receiver always switches to pro-logic with 47.1
post #1498 of 1712
I dropped a note on KVPT about the dropouts and they discovered a problem with the microwave link from the studio to the transmitter. My reception has been solid since.
post #1499 of 1712
KGPE is sending digital audio, just not 5.1 audio. That's why your receiver goes to DPLII. KSEE was the same way w/ NBC HD for quite some time. Only KFSN & KMPH seemed to carry 5.1 audio from the get go (or at least when I had the capability to receive it), although KFSN's was broken for a while early on (L/R only - no center, surrounds or sub).
I get HD locals via DirecTv & I find KSEE/NBC the biggest offender when it comes to audio dropouts.
post #1500 of 1712
Yes, I've noticed drop-outs on 24 also..I guess I just watch 47 more often.
thanks for the info...
