I'm helping some relatives who live near Woodlake. This is what I have done so far.
I put up an old CM 4228 which I got from a neighbor - - it is only about 22' above ground level.
I just ordered yesterday a Winegard AP 4800 Chromstar 2000 UHF Pre Amplifer (this should come in a few days)
My main question is - - - based on TV Fool radar plot most stations are 180 degrees apart. Can I use the Amplified CM 4228 to hopefully get both sides (meaning the 326 and 143 magnetic)? If so which is the best direction to point the antenna 326 or 143?
Also, is the antenna high enough - - - or do I need to go higher?
TIA
TIA
I hope this stays constant.
