AVS › AVS Forum › Video Components › Home Theater Computers › HTPC? does any one sell them pj ready?
post #1 of 2
hi guys ,just bought barco data 800. have almost decided to
use an htpc to enhance my picture. but i am not very computer friendly. does any one know anyone that could build one? it would be used exclusively for the home theater.
I was considering a dvdo iscan(not sure which model)but after reading the boards, would this give me a better picture?
thanks
Frank
frank
post #2 of 2
Well the obvious place to suggest is the fine providers of this forum AV Science or you could look to any of the following...
http://www.digitalconnection.com/index.htm
https://store.cellarcinemas.com/cgi-bin/store/index.html
Plus quite a few people here do occasional builds (you could do a lot worse than exchanging some email with xcel the other moderator)....
The exact resolutions that best fit your Barco would be down to you but if consulted the CRT forum you may find someone with more knowledge about optimum resolutions for this beast... Many builders will set up a custom T&R for you via PowerStrip if requested...
New email Phreddy@PhatPhreddy.net
HTPC without using windows... GUI Front Ends for Home Theater
This thread is locked
