Originally posted by kevlo9 I find that I get the best picture on the WARM setting. Also you really need to get a setup disc and use it to properly setup your colors.
Did you use a setup disc to get those levels??? Your contrast is set WAY TOO HIGH! My settings using Sound & Vision's setup disc...
4:3 mode
contrast-15/100
brightness-68/100
color-75/100
tint-2(in the red)
sharpness-10/100
SVM-off
ACC-warm
16:9 mode
contrast-15/100
brightness-60/100
color-65/100
tint-2(in the red)
sharpness-15/100
SVM-off
ACC-warm
I find that with setting I get a GREAT picture, espically on dvds.
I do notice "red push"(sometimes), just can't get in the service menu. |
Kevlo9,
I used both the AVIA and DVE discs to do my calibrating and I came up with almost the same exact settings as you did. Your 4:3 settings are almost identical to mine. My brightness is about 5 to 6 settings higher than yours. My biggest difference though is in the contrast and sharpness. My sharpness is 15 higher, and my contrast is set at 40. I will use your settings and see if I like the pic better or not. Just seems that contrast is set way low.
Quick question about SVM. Does it really make any diff whatsoever? If I have it set to HIGH, LOW, or OFF I don't really notice anything different. Am I just going blind, or is there really something to this feature, that by all accounts on the forum, nobody seems to like and maufacturers would be better off just eliminating it all together and adding something else?
