LPW
This is not uncommon in my experience, but usually a little trouble shooting solves it.
source and an interesting read: link
You may have this condition with your 3 separate circuits. You could try putting them all on one surge supressor to see if it eliminates the problem. It it does, then one by one move them to another circuit, if that's what you desire, until it returns.
If the above doesn't work you can looking into the following.
Does your amp have a grounding terminal? If so, and you have a surge supressor that has a grounding terminal - for your equipment - try grounding your amp to that terminal.
Is your cable or satellite hooked up to your system? If so, you may need to add a ground it at the splitter or add a simple grounding block and ground it to your supressor.
I hope one of these solutions helps.
Ground loop is a condition where an unintended connection to ground is made through an interfering electrical conductor. Generally ground loop connection exists when an electrical system is connected through more than one way to the electrical ground
