Just to add a note here on 12 V remote triggers. This was the problem on my setup. I have a B&K Ref 50 and the 12 V trigger to the B&K amp caused about half of the noise.
The other half was caused by a Parasound Scamp that I was using to remotely turn on the subwoofer amp.
So when you are looking for sources, especially with subs, don't forget to look here.
And also note that if you have your speakers cutoff at 80 Hz, the only place you will really hear the hum is from your sub since the hum is a relatively low frequency (60 Hz?) signal.
