Originally posted by enoree
Well......WLOS-DT is going down the tubes again, after the fix it was ok for a while, but now i get a good SS but the pic and sound freeze and unfreeze constantly making it totally unwatchable, there is no way they can convince me that its anything but a problem with their encoder, because WB40 is operated by them also and has no problems at all.
I just wanted to confirm a similar occurance with WLOS. I'm a little surprised no one else has mentioned it. I currently don't receive any signal from WLOS. It doesn't register on my signal meter at all. This is even worse than before. At least the first time it was broken, I could receive a very pixilated, although quite unwatchable, image. I could also change my signal strength by rotating directions - but could never get it quite strong enough for a watchable picture. Now I get zero picture and rotating the antenna doesn't cause any increase in signal strength. It just sits at "bad" and never increases (my signal meter goes from "bad" up to "excellent" rather than a assign a numeric value).
So what ever was wrong with it before, it is worse this time. Let's hope they can get their act together and fix it in less than one month this time.
Thanks for clearing that up Jerry.
