AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Greenville, SC - HDTV
Greenville, SC - HDTV - Page 295
post #8821 of 9749
Originally Posted by haroldt View Post
How do you mount one of these? Will it require constant adjustments?
Mine's on the roof, mounted to a regular antenna mast (with 2 supplied u-bolts), and on a rotor. If you don't have a rotor and don't want or can afford one, you can probably start by aiming it in the direction you desire, then tweak it (small aiming adjustments) until you're satisfied with the results. Then tighten up the mast or secure it in some manner to prevent unwanted movement.
Looking over your potential reception a few posts back, you will probably need to aim the antenna toward Greenville or Spartanburg. With WLOS and WUNF on Mt Pisgah being your strongest signals, you should have no problem receiving them even with the antenna NOT aimed toward Mt Pisgah.
post #8822 of 9749
I am a Charter subscriber in the Canton, NC area and I noticed earlier this week that the Music Choice channels, which I have received for 2 years without a cable box, are no longer there. Anyone know what's happened to them? I re-scanned this morning just to be sure and they are definitely gone.
post #8823 of 9749
I am sorry for the trouble. The Music Choice channels are now digitally encrypted and no longer available over QAM. A digital box (or cable card /w tuner) will be needed to get them. Let me know if you need any other help, or have any other questions!
post #8824 of 9749
I see it is true in Greenville/Spartanburg, too ... ah well, that's life.
post #8825 of 9749
Anyone else seeing an issue with signal quality on 29.1-29.3 Wntv lately? I'm getting weird minor stuttering/pixelation that just seems to have started this weekend.
post #8826 of 9749
Same here, but appears to be a signal quality problem rather than signal strength, as I am still getting a full 10 bars. No problem with SCETV on 49.1.
post #8827 of 9749
Thx tyler & am glad your seeing it also
Just spoke to one of the engineer's & they have some complaints about it so they know about it. Good to not be routed to india & actually talk to someone that can speak geek
This is my local PBS station that does a great job with a great antenna location.
post #8828 of 9749
Good afternoon, I wanted to follow up and make sure you didn't have any other questions/concerns regardinging the Music choice channels. Let me know if I can help!
post #8829 of 9749
In Taylors here with a decent pre-amp and an old rooftop antenna we get a good OTA signal from most of the stations. We are using converter boxes on old analog tvs, an older insignia digital tv, and a digital tuner for the computer. When we upgrade to a new digital set, do you have recommendations for which models have the best tuners for OTA signals. With the same signal, there is a significant difference in how well the tuners work. What shows clearly on the computer and one tuner will not come in at all on the insignia tv and one of the converter boxes.
post #8830 of 9749
Look at a Samsung 720p plasma. They display local OTA antenna TV very nicely, and have good tuners. They are a good bargain, as the PN51D450 has been at $549-$599 recently. The PN51D490 adds 3D, more features, and a more detailed signal meter. Also, the LG/Zenith 720p versions are similar and also have good tuners. If you consider Panasonic, I prefer their mid level 1080p versions such as the ST30.
post #8831 of 9749
Last week (Sat. nite) I watched Austin City Limits on UNC and the PQ was very odd. My receiver and TV noted the broadcast was in 1080p! I don't think ATSC is spec'd for that, has anyone else noticed this?
post #8832 of 9749
Any new developments? Still getting breakups in G'ville in spite of 100% signal strength.
post #8833 of 9749
They had it fixed the next day after i called them. It was a signal quality not quantity problem.
I'm OTA only, so if your viewing WNTV through cable or sat.......
post #8834 of 9749
Hmm... still having breakups OTA. Just wanted to rule out broadcast issues before more troubleshooting on my end.
post #8835 of 9749
I get both OTA and Directv and the pixelation was appearing on Directv as well.
post #8836 of 9749
At one point, DirecTV's local HD signals were retransmissions of what they captured OTA here locally. I'm not sure if that's still the case for all the locals, but it sounds like it is for 29.
-c
post #8837 of 9749
In Mauldin, I receive 3 SCETV signals with an antenna: 29, 38, and 49. And from NC, I get UNCTV on 33 and 17. So good reception of PBS here. And as far as I can tell, the technical problem on 29.1 has been corrected.
post #8838 of 9749
That is a mistake because OTA broadcasts can only go as high as 1080i and you cannot see any 1080p unless you use Blu Ray or perhaps an On Demand PPV movie.
Doug would know best of course why you might be seeing the errant setting.
@Doug ....why would chroma601 be receiving a display reading that indicates 1080p? I'm thinking that the program was recorded using blu ray HD technology or something similar and it is "fooling" the TVs display data .
The OTA posibilities are 480i ,480p, 720p and 1080i.
post #8839 of 9749
ATSC does support 1080p/24 or 1080p/30, but not 1080p/60.
- Trip
post #8840 of 9749
On DirecTV, my UNC public tv channel 33 is also coming in at 1080p and though the receiver supports that resolution for PPV and OnDemand, the bottom part of the screen exhibits pretty bad tearing on channel 33. I don't have a decent enough antenna to test reception OTA.
-c
post #8841 of 9749
Hi all i am new here but hoping to get some advice.
My mom, up until recently, has been in the dark ages using 3 SD tv's wiith OTA reception through digital converter boxes.
I recently talked her into buying a Digital HDTV (she chose the Toshiba 46SL412) When the Best Buy guy delivered the TV and hooked it up for her, he set it on antenna and went through the autotune. For some reason, none of the Channel 13's would program. Her other two TV's (still on converter boxes) get 13 fine and she has a good antenna mounted on top of the house.
My question is, anyone else in the Asheville NC area having similar problem and could this be a bad reciever on the Toshiba? Doesnt make sense to me that a popular brand would be unable to tune a strong network station. I am out of state and unable to help her.
thanks for any advice you may have.
post #8842 of 9749
- Trip
I was certain that when I was reading engineering articles about ATSC that no OTA broadcasts could utilize any form of 1080p only 1080i .
Trip or Doug has this always been possible since the broadcasters in the US began ATSC digital broadcasts to the general public some years ago?
Maybe only recently they have been offering 1080p? Hmm very interesting for sure.
post #8843 of 9749
Did she indicate what channels she IS getting?
post #8844 of 9749
Well. i know she IS getting the other networks like Fox, CBS, and NBC. Not sure about PBS. I will have to ask her. I think she is a victim of a poor signal. She lives in the mountains of western NC so maybe she needs a powered antenna? But its weird that the station comes in through the el-cheapo digital converter boxes to her old SD televisions.
post #8845 of 9749
Asheville has a rep for difficult digital reception that's real. From what you've said I would recommend a small Hi-VHF antenna like an Antennacraft Y5 7-13 to grab Wlos better. You'll need a UVSJ combiner & a couple patch RG6 cables.
However,I could be wrong. AVille is a tough nut to crack....
post #8846 of 9749
There are many possibilities as to what may have happened to her WLOS reception, and I'm sure it's frustrating because she previously received it. There can be noticeable differences in performance between tuners, and one would think that a newer one (especially built-in to the set) would perform as good or better. Without knowing her exact setup it would all be pure speculation. Is she using a rooftop or indoor antenna? If outdoor, how old is it? The weather can takes it toll on an antenna after an average of 20 years. Weather also takes its toll on the cable (preferably RG6) running from the antenna to the TV. If this is an outdoor antenna, is there a preamp? If so, it's possible the new TV's tuner is more sensitive to signal overload (from WLOS), which would cause WLOS to be unwatchable. You can also input your mother's address into these websites to determine the channels she can potentially receive:
http://www.tvfool.com/
http://transition.fcc.gov/mb/engineering/maps/
post #8847 of 9749
Strange though that he says his mother gets CBS - I'm assuming WSPA - as it's on VHF. However, she could be watching WSPA on channel 62-2.
post #8848 of 9749
Thanks for all your replies. Its defintiely an odd situation because the other two TV sets are still using the digital converter boxes and working well so perhaps the tuner int he new tv is a bit wonky.
Thanks for the links to the websites to find out what stations she should get that will be helpful.
To answer some other folowup questions.. The antenna is under two years old and is roof mounted. All associated wiring is new as well. Apparently she is NOT getting PBS as well. I will let you know if i get this resolved
post #8849 of 9749
Originally Posted by GVLSandlapper View Post
Has there been any word from Charter if they're adding AMC HD in time for Mad Men season 3?
Originally Posted by fowlerbt View Post
Have we heard why we don't get ESPNU HD? or is that on a sports/premium tier? (Charter, Greenville)
Just heard back from the marketing director. Unfortunately we won't be adding either of these channels this year.
Do you have any updates on these two channels?
post #8850 of 9749
Good Afternoon,
We do in fact have some news on those as well as quite a few other channels!
Here's a list of upcoming changes:
Effective 12/6/2011,
ADDS:
E! HD on ch. 744 (Exp Basic (HD Only))
Style HD on ch. 745 (Exp Basic (HD Only))
Oxygen HD on ch. 746 (Exp Basic (HD Only))
Nickelodeon HD-East on ch. 758 (Exp Basic (HD Only))
ABC Family HD on ch. 760 (Exp Basic (HD Only))
Cartoon Network HD on ch. 759 (Exp Basic (HD Only))
Turner Classic Movies HD on ch. 771 (Exp Basic (HD Only))
Travel Channel HD on ch. 764 (Exp Basic (HD Only))
AMC HD on ch. 772 (Exp Basic (HD Only))
TruTV HD on ch. 774 (Exp Basic (HD Only))
OWN HD on ch. 775 (Digital View Plus (HD Only))
ESPN U HD on ch. 810 (Digital View (HD Only))
ESPN U HD on ch. 810 (Sports View (HD Only))
Lifetime Movie Network HD on ch. 750 (Digital View (HD Only))
MSNBC HD on ch. 790 (Exp Basic (HD Only))
HLN HD on ch. 791 (Exp Basic (HD Only))
VH-1 HD-East on ch. 875 (Exp Basic (HD Only))
Spike TV HD-East on ch. 844 (Exp Basic (HD Only))
CMT HD-East on ch. 876 (Exp Basic (HD Only))
BET HD on ch. 877 (Exp Basic (HD Only))
Investigation Discovery HD on ch. 769 (Digital View Plus (HD Only))
EPIX HD on ch. 894 (HD Premium)
Disney XD HD on ch. 757 (Exp Basic (HD Only))
Did you have any other questions we could assist with?
Dylan
http://www.charter.com/Umatter2Charter
