AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Greenville, SC - HDTV
Greenville, SC - HDTV - Page 310
post #9271 of 10293
Originally Posted by SpencerKarter85 View Post
tylerSC, I've got WLOS 13 ABC temporary hours earlier. Do you think I should order preamps online or go to Radio Shack in Greenwood, SC?
The Radioshack preamps have a higher noise figure and don't always work as well as the other brands such as Winegard. And they cost more. For cost and performance, I would order the Winegard 8700 from Solid Signal for $29.
post #9272 of 10293
Originally Posted by pinhunter27 View Post
THanks for everyones input. THat would be also if they put a transponder on parris mountain.
Tyler I tried all of your suggestions. I managed to pull WLOS for an hour after work yesterday and then it disappeared.
However I found a long coaxial and moved the antenna temporary out on my deck and voila. Perfect reception to the major 5 ( WLOS, WSPA, FOX, NBC and WMYCA (i think).
So I may be able to get a small footprint outdoor antenna (RCA ANT 751) and put it on the side of my house and use the charter feed to my living room. Im going to give that a try. It will not be very high in the air and it may not work. I believe my chances are better with this antennae to receiving WLOS. I know the indoor antenna will not work consistently no matter where i place it inside my house.
Hopefully WLOS will put a tower on Parris Mountain. Who knows, If this works I will not need it.
THe antenna gets mostly great reviews for it's reception and small form factor. I know it's not the best but it's cheap and all I really care about are the 5 networks. Listed above.
Go to Radioshack and get an Antennacraft HBU22. It is also a small antenna that is perfect for AVL/GSP market, as it gets HiVHF and UHF. And adding a low gain preamp may also help. Antennas Direct PA18 is $27.99 with free shipping from Solid Signal, and Winegard 8700 is $29. And depending on where you place your antenna, you can also receive some Charlotte channels.
post #9273 of 10293
It doesn't mention RF 31.
take look here
http://www.rabbitears.info/market.php?request=station_search&callsign=190612#station and here
http://transition.fcc.gov/fcc-bin/tvq?facid=190612
Licensee: WLOS LICENSEE, LLC
Service Designation: LD Digital Television Translator station
Transmit Channel: 31 572 - 578 MHz Application
Virtual Channel: (viewer sees this channel number)
post #9274 of 10293
Originally Posted by tylerSC View Post
I wish they would let Jack Roper do the weather again. Especially now if he has meteorolgy credentials.
I agree also. they could add a 4:00pm Newscast and let Jack Roper do the Weather. or changed the Your Carolina format into a Mid Morning news format and add a Weather sagment
post #9275 of 10293
I've got some good news on DXing and Tropo things via my Philips Indoor Antenna SDV1125T/27 despite haven't put up my AntennaCraft C490 Long Range Outdoor one yet. I've picked up 2 Atlanta, GA stations over-the-air at this hour.
WSB 2.1 (ABC) and 2.2 (MeTV) which is RF 39 and 131 miles from my house. And WAGA 5.1 (FOX O&O) which is RF 27 and about 129 miles from my house. Signal is depixelating on WSB 2 and WAGA 5. So far, I've pick up three Hotlanta TV stations WSB, WAGA, and WPCH. I haven't pick up WXIA, nor WGCL, WUPA, nor WATL or GPTV 8 and PBS 30 over the air. What do you think? smile.gif
I Pickup the Channel 12 WXII this morning on my indoor Philips pre amp antenna. along with the WHKY 14 and WCCB 18 and WGGS 16 WSOC 9 along with my main channels.
post #9276 of 10293
The Charlotte Observer confirms this morning that Malachi Rogers is indeed coming to WSPA. But the Mark Washburn column does not provide further details. Picked up the paper at Publix this morning.
here is another report
http://rogersimmons.com/malachi-rodgers-leaving-wesh-for-south-carolina-station-plus-other-o-town-moves/2012/08/11/
post #9277 of 10293
I emailed Christy Henderson about Dan Brickford he is moving to the Weekends newscast and do Weather stories during week from time to time and be Christy Fill-in when she is out.
post #9278 of 10293
I've went to RadioShack and bought an in-line signal amplifier today. I had $60 and I don't want to go over priced. But I did some scanning on the channels. Still no WLOS 13 frown.gif
I wish WLOS' signal wasn't inadequate.
post #9279 of 10293
SpencerKarter, that Radioshack inline amp is lousy and a poor choice. If you are going to get an inline amp, a better choice is the RCA inline amp at Walmart which is $15. It is designed to have Extremely Low Noise, so should be better than the Radioshack. But actually, an inline amp is not appropriate for your situation. YOU NEED A GOOD LOW NOISE PREAMP.
post #9280 of 10293
I don't know if anybody remember the old Cable Channel The Nashville Network well
Luken Communications and Jim Owens entertainment is going to Rebirth the Nashville Network into a Digital Television station & Cable Station
http://watchtnn.com
Luken Communcations is owners of RTV Network and part owner in MYFamilyTV
post #9281 of 10293
Originally Posted by LMckin View Post
take look here
post #9282 of 10293
What happened to the original Nashville Network? Did it become a different cable channel?
post #9283 of 10293
I've found out that RF 31 is also Augusta, GA's WFXG 54's RF number. And unfortunately it's not reaching my area frown.gif
post #9284 of 10293
The Original Nashville Network is what is now Spike channel.
post #9285 of 10293
So when ever they get the Appilcation Approve and get the Translator equipment install and a Antenna Install Two other stations has a Broadcast antenna on Paris Mountain WNTV ETV 29 and WGGS 16 so once they put that Translator on the air then that should help the Upstate area to get the WLOS TV
post #9286 of 10293
Hope they are allowed enough power to cover the Upstate area.
post #9287 of 10293
post #9288 of 10293
SpencerKarter are you going to order a real preamp?
post #9289 of 10293
Wow. Sharon Osborne's eye makeup on NBC looks like Tammy Faye tonight. RIP.
post #9290 of 10293
When I get my next SSI check.
post #9291 of 10293
Do you mean RCA TVPRAMP1R Outdoor Antenna Preamplifier? http://www.amazon.com/RCA-TVPRAMP1R-Outdoor-Antenna-Preamplifier/dp/B003P92D9Y/ref=sr_1_5?s=electronics&ie=UTF8&qid=1345017440&sr=1-5&keywords=RCA
post #9292 of 10293
tylerSC, I've saved Winegard 8275 preamp in my wish list at Amazon website. smile.gif
BTW I've got WNSC 30 (PBS/SCETV) from Rock Hill, SC in the Charlotte, NC DMA OTA which is 79 miles from my house. Unfortunately no signal, getting so-called blue screen of death instead. frown.gif
post #9293 of 10293
Ahh, but was this Dan Bickford's choice??? If so, she could not comment on such.
post #9294 of 10293
Regarding WLOS translators...
I was reading on Facebook the comments regarding WLOS and the impending loss of carriage on DISH Network. You know, same song different verse, blah, blah, blah - my commentary on these carriage fiascoes. Anyway, one WLOS fan posted that many translators in the far western NC mountains are now off (since the digital transition) - and apparently they are not returning (in digital or otherwise). Does anyone have a good list of WLOS translators, and which ones are off and will not be returning in digital form? Because of the length of translator callsigns, they are almost impossible for me to memorize, and their COL is not always logical - therefore I find it difficult to search for translators on the FCC site. It would be a nice public service for stations to consistently post translator information on their websites, but most don't.
Eric
post #9295 of 10293
Double check Solid Signal price, but Amazon has free shipping so you may come out better there. The RCA preamp may be decent, and claims low noise. But they also have an inline amp at Walmart for $15, but that is not what you need. The 8275 has more gain than the 8700, so may be better at your distance.
post #9296 of 10293
SpencerKarter, are you getting good reception tonight? Conditions appear to be very good, and I am getting all Charlotte channels very strong, as well as the GSP locals of course, including AVL. But it will be nice if WLOS adds their translator if FCC approves.
post #9297 of 10293
You must be asleep tonight SpencerKarter. No updates yet. And have you thought about getting a rotor, since you also may want Columbia and Augusta?
post #9298 of 10293
tylerSC, right now I'm having trouble getting WYFF 4 OTA! Also yesterday I've picked up WLOS 13 again during the afternoon but signal disappeared. frown.gif
Yes, I'm pointing at the right direction as the best as I can.
post #9299 of 10293
Eric
Go here to get a List http://www.rabbitears.info/market.php?request=station_search&callsign=190612#station
post #9300 of 10293
Why on earth is Wheel of Fortune is on WMYA 40 tonight instead of Family Feud?? I wish they mention program note thing.
