Originally posted by atlantica JenEric,
I just reproduced the problem!!! I'm collecting the diagnostic info right now and will include it in a follow-up posting shortly... |
OK, here's what I did:
1. Downloaded and used Version 12 of evtEdit that JenEric posted earlier.
2. Kept my configuration settings the same (except pointed evtEdit to a new "WorkArea" directory for the .mpg, .evt, and .ndx files.
3. Copied the files for my largest video from DVArchive (Blues Brothers at about 7GB) to this special WorkArea directory.
4. Ran evtEdit and changed a few segments that were incorrectly marked as commercials (red) and changed them to valid content (green), and vice versa.
5. Hit the "convert mpeg" button.
6. Immediately got the following displayed on the console windows that popped up:
F:\\Temp>"C:\\Downloads\\ReplayTV\\RTVTools\
ev4\\bin\\win32\
tvedit.exe" "F:\\Temp\\evtEditIn_3724.txt"
Can't open file F:\\DVArchive\\WorkArea\\The Blues Brothers.mpg
F:\\Temp>pause
Press any key to continue . . .
7. At this point I checked my temp directory (i.e., F:\\Temp) and found the following files (which are included in the zip file attached to this posting):
evtEditIn_3724.txt
evtEditLog.txt
RunEvtEd_3724.bat
8. I checked F:\\DVArchive\\WorkArea and it is completely empty (the original .mpg, .evt, and .ndx files were deleted).
9. Inspecting the evtEditLog.txt file, the last line says:
1/13/2004 8:39:13 PM: Deleting F:\\DVArchive\\WorkArea\\The Blues Brothers files. (EditMpeg DMG1)
So it seems to me that evtEdit is deleting the files and it's doing it before rtvEdit even got started.
JenEric, do you need any more info to debug this? I'm going to leave evtEdit at the state it's in for a while (console window still displayed, sitting on a pause) in case there is any other info I can collect for you. I believe if I continue on from the pause, the evtEditIn*.txt and RunEvtEd*.bat files will get deleted.
Let me know...
