| Originally posted by BrownRB O.K., here's my latest challenge for Harmony: I have the usual HT stuff, but I also have a separate preamp that drives a whole-house system with speakers in every room, getting its source via tape-out from my HT receiver. Sometimes I want to listen to music out of the HT receiver and the preamp at the same time which means that I need to have control over both volume controls. I need to be able to quickly toggle back and forth between the HT receiver and preamp volume controls. (I have IR repeaters in every room). Can the Harmony SST-659 handle this? |
While in an Activity, you can press the "Device" button to bring a list of your programmed devices onto the LCD. You scroll through the pages of devices until you see the one you want to switch to and then push that button. This could be 2-7 button pushes (depending on which page your desired device is on) so I don't know if this is quick enough for you. To switch back, just press the Activity button again and the remote will switch back to the default Volume Control. I don't know if there is an easier way (it seems like there should be but I haven't had any reason to look into it so I don't know).
