Originally Posted by pjp
They're easy to mount as long as you have a solid surface to attach to. I would think on a couch there would be plenty of bracing underneath to attach to, but depends on the model. On reclining chairs or couches, you need to make sure the shakers can't get caught on anything when reclining and also ensure that the wires are secured so they can't get caught in the moving parts during recline.
Thanks, interesting feedback. They mention an Aura modification in that thread. I found it here: http://www.keohi.com/keohihdtv/acces...uykuo_mod.html
I might give this mod a try to lower the resonant frequency. I haven't found the Auras lacking, but sometimes you don't know what you're missing until you try something better. I do find the Auras requires tweaking for different movies, so maybe it's because the resonant frequency is higher on the Auras.
Good info -- thanks for sharing
I corrected a typo in my post above. Auras and K-Woons go down to 20 Hz, not 10 Hz.
