Originally posted by miltimj
Bud, the two links you posted are exact opposites.. you want the low pass so the only frequencies you receive are below that point (though it's not a hard cutoff, but heavily sloping).
The problem with using your receiver is if you have a sub in addition to the shakers (highly recommended by the way), you can't send a different signal from one to the other... it'd be one thing if the sub was supposed to be lower than the shakers because then you could use the crossover on the sub, but unfortunately it's the opposite.
So... I will use the receiver's processor/built-in crossover to effectively be an 80Hz low pass, split to my shaker amp (receiver) and sub, and use an FMOD to further limit the frequencies reproduced by the shakers.
Yeah, I thought that was the case. I haven't thought through the whole thing completely yet, but I was thinking of using two receivers (an old Kenwood to power the shakers) and plan on buying the Yamaha RXV-2500. From the Yamaha receiver, "Y" the sub out connection and have one side go to the sub and the other go to an input of the Kenwood receiver (not sure if this is doable or how the exact connections would be yet). I would assume after the Y split, I could attach the FMOD before (either end of the RCA patch cable) the Kenwood for the shakers. This would limit the lower frequencies just to the shakers. If this is doable, I would think I would have to split the overall input to the Kenwood into a Left and Right audio input? Or can I get away with a sub out and a sub pre-out connected to the Kenwood? I plan on 8 aura shakers and run two serially into the left and right channels on both A and B speaker selections (already tested this).
Thoughts?
Bud
