AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › LCD Roundup Sticky
LCD Roundup Sticky
post #1 of 19
I just thought it may be worth while listing all the current and announced large form factor LCDs (=> 30") in one thread before the next slew of announcements (presumably at CES). I paid special attention to diagonal size, resolution and total unit size. I'm sure I missed a few so please add any that come to mind, thanks!
Announced Products: :rolleyes:
Samsung LTN468W (46" 12ms GTG, a 1280 x 720)
http://www.samsung.com/PressCenter/P...025_0000000404
http://www.hdtvexpert.com/Pages/steamroll.htm
Samsung LW54G1D1 (54" 1920x1080)
http://www.samsung.com/Products/TV/F...VLCD/index.htm
http://neasia.nikkeibp.com/wcs/leaf?...bt/news/275714
Net Dimensions without stand: 1547 mm (W) x 766 mm (H) x 101 mm (D)
Samsung 57" (1,920 x 1,080)
http://www.theinquirer.net/?article=12906
BenQ 46" (1,920×1,080, 800:1 contrast, 600-nit brightness)
http://www.digitimes.com/NewsShow/Ar...ages=A7&seq=48
CMO 47" (1920x1080 resolution, 8 msec GTG, a brightness of
800 nits, and a contrast ratio of 800:1)
http://www.cmo.com.tw/english/showne...20031028100134
http://www.digitimes.com/NewsShow/Ar...ges=PR&seq=202
AU Optronics 46" (1920×1080, high color
saturation (75% NTSC; EBU>100%), 600-nit
brightness, 800:1 contrast, 12ms GTG)
http://www.digitimes.com/C2/C2.asp?d...ges=C2&seq=402
LG 52"..... ROGO what was that you said about the 55"???
Available Products: :cool:
37- 40" Monitors
NEC LCD4000 (40" 1280 x 768)
http://www.necmitsubishi.com/css/Tec...00_drawing.pdf
http://www.necmitsubishi.com/product...c_id_index.cfm
Net Dimensions without stand: 37.4" (W) x 23.8" (H) x 5.6" (D), 949 mm (W) x 605 mm (H) x 141 mm (D)
Samsung LTN406W (40" 1,280 x 768- Consumer Model) [url]
http://www.samsung.com/Products/TV/F...CD_LTN406W.htm
Net Dimensions without stand: 38.9" (W) x 28" (H) x 3.4" (D)
Samsung 403T (40" 1,280 x 768- Commercial Model)
http://www.samsung.com/Products/Moni...nitor_403T.htm
Dimensions 38.3x26.5x3.9 (WxHxD) inches
Sharp LC-37HV4U (37" 1366 x 768)
http://www.sharp-usa.com/products/Mo...8,1069,00.html
Net Dimensions without stand: (w x h x d) 37.3" x 23.1" x 3.2"
Net Dimensions without speakers: 46 19/32 (W) x 23 1/8 (H) x 3 7/16 D
29-32" Monitors
Samsung LTN325W (32" 1280 x 768)
http://www.samsungusa.com/cgi-bin/na...LTN325WX%2fXAA
Net Dimensions without stand: 31.5"(W) x 23.5"(H) x 3.4"(D)
Toshiba 32HL83 (32" 1280x768)
http://www.tacp.toshiba.com/televisi...p?model=32HL83
NEC LCD3000 (29.5" 1280 x 768)
Net Dimensions without stand: 27.8" (W) x 17.7" (H) x 4.5" (D), 706 mm (W) x 449 mm (H) x 114 mm (D)
Mitsubishi LT-3020 (30.0" 1280 x 768)
http://www.mitsubishi-tv.com/Downloa...ManualLCDs.pdf
Net Dimensions without stand: (has built in speakers)
Sharp LC-30HV2U (30.0" 1280 x 768)
http://www.sharp-usa.com/products/Mo...1,1023,00.html
Net Dimensions without stand: (w x h x d): 39 15/32" x 19 9/16" x 3 21/64"
LG L3000A (30" 1280 x 768)
http://www.lgeus.com/Product/monitor/L3000A.asp
Dimensions With Base (WxDxH) 28.9" X 3.7" X 19.2" (734mm X 94mm X 487 mm)
LG MW-30LZ10 (30" 1280 x 768)
http://www.lgeus.com/Product/monitor/30LCD.asp
Net Dimensions without stand: (wxdxh) 29.9" x 4.1" x 19.4"(759 x 492 x 103mm)
Philips 30PF9975 (30") (30" 1280 x 768 - LG rebrand)
http://www.consumer.philips.com/glob...=FLAT_TV_CASet
Dimensions (WxHxD) : 891 x 489 x 110 mm
Zenith L30W26 (30" 1280x768) (30" 1280 x 768 - LG rebrand)
http://www.zenith.com/index.asp?url=...eywords=L30W26
Dimensions (W x H x D): 29.9" x 21.46" x 7.78"
Dimensions with Packaging (H x W x D): 33" x 26.2" x 14.4"
Sony KLV-30XBR900 (30" 1280 x 768 - LG rebrand)
http://www.sonystyle.com/is-bin/INTE...XBRKIT&Dept=tv
Net Dimensions with stand: (has built in speakers): 38.2" x 20.6" x 3.7"
post #2 of 19
Thanks Alex... long time listener, first time caller. I am shopping in the 32"-42" panel range in the upcoming 6-12 months, and I prefer the fill factor of LCD over plasma at my 8' viewing distance (or HD plasma if money were no object.) I read the forum daily and scour the net for great panels at great prices, and I anxiously await the inevitable price drops and performance/size increases. They're getting close to the point of making my trigger finger itch. April 15, '04 will probably direct my financial decision making (for better or worse...)
Here are a few more displays for the roundup in the available 29"-32" range. As a new member, I cannot post links--maybe someone can fill them in for me.
Medion 30 (30" 1280 x 768)
(find info from a seller on videogon)
Dimensions 35" W x 3.01" D x 18.5" H
Dell W3000 (30" 1280 x 768 probably a rebadge?)
see dell.com
Dimensions H: 19" x W: 40" x D: 3.8"
Panasonic TC32-LH1 (32" 1280 x 720 (!))
see panasonic.com
Dimensions ?
Gateway 30" LCD (30" native resolution = ? must be a rebadge)
see gateway.com
Dimensions 32.6"H x 16.18"W (sic) x 4.13"D (I think they transposed W/H)
Cheers!
post #3 of 19
Regarding the 1920x1080 displays I think we should
differentiate between 'demonstrated' or 'paper propaganda
war', and commercial announcment meaning products coming
to shops.
In this sense only AU Optronics was announced, coming
to shops in Taiwan in Q1/04 with list price 299 kNT$.
55" from LG and 57" from Samsung are on the propaganda
war level and it is probably not the end of it, next salvo from
LG.
post #4 of 19
to shops.
LG.
I whole heartedly concur- potential shoppers should definitely take those announcements mentioned with a grain of sand. Over the last year we've seen major announcements (i.e., Samsung 54" at CES 2003), but with the product(s) being so far out (Mid 2005 for general availability) the spec will almost certainly change from what's said today. The reasons I include the announcements (as segregated from existing products) is to give people a taste of things LCD to come in preparation for CES, and also to minimize the need to searching for all these announcements from various threads here- that I had to shuffle through in order to compile.
post #5 of 19
Alex, LG showed a 52" prototype.
Then then showed a 55" prototype seemingly to "beat" Samsung, who had even gone so far as to give their 54" a product moniker.
I no longer know if LG intends to ship 52" or 55" and I no longer know if Samsung intends to ship 54" or 57".
The roundup is cool. FWIW, though, I don't think an AUO or CMO-branded model has even a 1% chance of shipping here in the U.S. Instead, both of those panels will doubtless be OEMed by someone else who will bring them here.
post #6 of 19
Sony has announced two new LCD panels, 42" and 32". Both of which can be seen here.
They were posted in the Flat Panel Display thread with 1394, ATSC tuner thread above.
Troy
post #7 of 19
FYI - the specs are out on the gateway model. It is 1280x768, DVI, dual component, rgb etc etc. It looks identical to the Dell. In fact, I believe they are the same manufacturer - even the lights and switches are in the same place. I just ordered one. Some specs are here:
http://support.gateway.com/s/Manuals...er/8509482.pdf
Moderator Note: removed pricing info: would like to make this thread a sticky
post #8 of 19
One More?
How about the Infocus TD30 ?
1280 x 768 resolution
450 nits brightness
350:1 contrast ratio
170° viewing angle
PC Connectivity: DVI, VGA
Video connectivity: S-Video, composite,
and component (x2)
Control: 9-pin DSUB
Built-in NTSC TV tuner
2 x 5 Watt stereo speakers
Signal compatibility: VGA - SXGA
Operating temp: 5° - 30° C; 41° - 86° F
Power consumption: 170 Watts (maximum)
Backlight: 50,000 hours minimum life
Picture-in-Picture
29.6" diagonal TFT active matrix
Color: 16.7 million colors/24 bits
Pixel pitch: 0.1675mm x RGB (H) x 0.5025mm (V)
Product Warranty: Registered owners receive a 1-year limited parts and labor warranty
post #9 of 19
LG announced a 42" before the 50+" sizes. A quick search here turned up the following thread: http://www.avsforum.com/avs-vb/showt...ighlight=42+lg
It is indicated that this may show up as a product some time next year.
Also, the current model Zenith 30" is the L30W36.
http://www.zenith.com/sub_prod/produ...?cat=11&id=163
Robert
post #10 of 19
Here's the LG link.
http://lgappliances.com/products/mod...sma_index.html
post #11 of 19
Originally posted by Chris J
Here's the LG link.
Chris,
I think you mean this one (LCD), correct?:
http://lgappliances.com/products/models/lcd_index.html
post #12 of 19
I was looking at the CES website, and they have a list of products that will be shown here . For large LCDs, I see the following:
1. LG Electronics
30" Widescreen Fully Integrated LCD HDTV
30" Widescreen LCD Integrated HDTV DU-30LZ30 - 1280 x 768 WXGA Resolution - Integrated 5th Generation LG/Zenith VSB Chipset ATSC/Digital Cable (clear QAM)/NTSC Tuners - SuperIPS Technology: 176° Viewing Angle
2. LG Electronics
42" Widescreen Fully Integrated LCD HDTV
World's Largest 42' Widescreen LCD Integrated HDTV DU-42LZ30 - 1366 x 768 WXGA Resolution - Integrated 5th Generation LG/Zenith VSB Chipset ATSC/Digital Cable (clear QAM)/NTSC Tuners - SuperIPS: 176° Viewing
3. Philips Consumer Electronics
42" LCD High Definition Monitor TV with Ambient Lighting and Pixel Plus 2
42PF9996 - 42" LCD TV with Pixel Plus 2 , Ambient Light and invisible flat NXT speaker technology - the viewing experience TV.
4. Samsung Electronics America
Samsung's 46 " Wide Screen HDTV Monitor LCD TV (LTP468W)
The LTP468W is not only the world?s largest LCD HDTV, it also offers a full 1920 by 1080 progressive scan resolution for outstanding resolution and image clarity.
Robert
post #13 of 19
FYI
a link to this thread will be added to the FAQ and this thread will remain open, but will soon be 'unstuck'
post #14 of 19
I notice on the LCD roundup that the Phillips 30PF9975 is called "LG rebrand". What does that mean?
I just bought this Phillips at a great deal (< $1,900.) to be a decent quality LCD for a very small living room. The perfomance is OK, the cabinet not sleek, and I am thinking of returning it.
Any opinions on this TV?
If its the LG 30" with Phillips "shell" and name, then its really a fab deal!
gemstoner
post #15 of 19
LG-Philips is a conglomerate brand name. Usually a good deal of high end LCD products are distributed in Asia simply branded as LG, the Korean company that makes the displays and sells them to the rest of the world slightly re-packaged (LG-Philips) or totally re-integrated (e.g., some Dell, Apple parts). This does not mean, however, that Philips Electronics of the Netherlands had not substantively contributed Intellectual Property to any given LG product.
post #16 of 19
because my next HDTV display will be a 1920 x 1080 LCD whose width (speakers on the bottom) is less than 40" (due to cabinet restrictions). When it looked like there would be a lot of 40" monitors, I was fine. Now that it looks like 42" is becoming the norm, I'm worried that I'll have to fall back to 37". Does anyone agree with this trend, and will there be 37" full HD resolution panels anytime soon?
post #17 of 19
Don't know how current this is - the LT37HVi is shown as LT37HVS elsewhere on the site:
Here
post #18 of 19
We can add the Westinghouse Mdl LTV 32w3 HD coming in Sept. Has 1,000:1 CR, 550 cd/m, 1366x768 resolution, 75% color gamut, 8ms response time and 176 degree viewing angles. It will have both HDMI and DVI inputs with HDCP.
post #19 of 19
Like the smaller Westinghouse LTV-27w6 with ATSC tuner, also available in September, CableCard is not mentioned. Specs are HERE
This thread is locked
