AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › Unlocking TIVO's 30 second skip
post #1 of 8
I have read that there is a way to get TIVO to do a 30 second skip like Replay does. Anyone heard of it? Thanks.
post #2 of 8
While you are playing back a recording, enter the following:
Select-Play-Select-3-0-Select...
post #3 of 8
Thanks, but the big trick is hitting 6 keys vs. the Replay one??? I thought there was something to "unlock" a special key or something like that. Oh well, thanks again.
post #4 of 8
if you enter those six keys, it turns the "Skip To End" key on the remote to a 30-second skip key. so from that point on, just press that one button and it will skip 30 seconds.
post #5 of 8
post #6 of 8
Works on my Samsung DirecTivo too. Thanks.
BTW, how do you switch the skip to end button back?
post #7 of 8
Repeat the S-P-S-3-0-S or reboot.
post #8 of 8
Just to further what yesno said.....after you "enable" 30-sec skip on a TiVO, if you have any sort of a reboot (i.e., if the power goes out), you will have to re-enable the function. And for me it is a "one button" press as I have a hidden button on my Pronto that does it all for me......
This thread is locked
