AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › unsubscribed new channels
post #1 of 4
Months ago it was brought up that Replay should not automatically add new channels to the line up. Has any work been done on this? My assumed answer is no, because I keep getting all these different channels that I have to go and maintain. I hope this gets resolved in 3.1.
Cheers
ReplayTV -- The only one that had firewire...
post #2 of 4
.....I hope there IS a 3.1
I know what you mean. I have to enter setup once a weekk to disable all the channels in the 400, 500 & 600 range they keep adding.
My TiVo units do the opposite, and don't add the channels unless you manually do. They also send a message that there is a lineup change.
post #3 of 4
I have to second the "make them show up turned off" idea. I have the same problem when new local are added to DirectTV. They confuse the theme channels if they are not deleted and that means that I have to go in and search them out each week. Too much trouble.
post #4 of 4
And Dish Network has no easy way out of an unsubscribed channel.
Cheers
  Back to Forum: ReplayTV & Showstopper PVRs
This thread is locked
