AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › Unintentional Mass Deletion
post #1 of 7
I don't know if anyone else has experienced this, but I figured I should warn all of you that it might happen.
I had to go away on business for 2 weeks over Thanksgiving. I set my 3060 to guarantee 15 episodes of Babylon 5 at medium quality. When I came back it seemed perfect. All of the episodes were there with their proper headings and descriptions. After I watched the first episode, I tried to delete it (as I have done sooo many times before). For some reason (and this is the first time this happened), the system completely locked up (crashed). The only thing I could do was re-boot. After the re-boot, all of my channels were there, but all of my Babylon 5 episodes were gone. Other programs, however, were not deleted. As any of you who watch Babylon 5 know, in 2 weeks a lot happens on the show! Just thought I'd bring this to everyone's attention as a possible glitch. Has anyone else experienced this and if so, is there a way to avoid it (ie. don't try to record more than __ episodes of something).
post #2 of 7
I once deleted a set of shows when I bumped the cursor over from the individual show over to the main show block and deleted the whole record instead of the individual show. A mistake that can happen. Major bummer.
Just make sure you are deleting the correct thing when you press delete. Maybe you found a glitch... but it could have been a duplicate of my mistake.
post #3 of 7
Don't take my skeptism personally, I just think I know what ya did. You went to Replay Guide to delete the episode, but by accident selected the whole Show-based Zone, thereby deleting all episodes contained within it.
The only constant is change.
post #4 of 7
I'm pretty sure I didn't do those things, all I did was hit "select" when I was prompted to after the show ended.
post #5 of 7
Well, crazier things have happened. These are all just dressed up PC's and as such there will always be anomolous behavior, sometimes resulting in unpleasant results http://www.avsforum.com/ubb/frown.gif
post #6 of 7
I had posted a similar problem with my new Replay 3060 w/3.0 locking up after deleteing 1 show in a group of shows that I had collected. I had to do a hard reset to get it back. I did as someone here had suggested and deleted that show group and re-entered it again. I had had 3 lockups initially and none since the delete and re-enter.
post #7 of 7
Thanks Mike.
  Back to Forum: ReplayTV & Showstopper PVRs
This thread is locked
