Originally Posted by
MikeAlletto
Anyone know when Austin is going to get smacked with the new Navigator software? From a few of the above posts it sounds like non-dvr boxes either already have it or are getting it? (Samsung boxes??)
The new samsung boxes have Navigator/Mystro it pre-installed. The Scientific Atlanta boxes *should* be getting it on 4/1, but I have no information on which specific models if not all will be receiving it.
Petrus
I called yesterday to inquire about when we are getting new HD-DVRs. The rep said we should now be getting the Samsung 3270. I plan on taking my 8300HDC for a swap as soon as I finish out my recorded shows.
I don't think they have the DVR's quite yet in the Lobbys, for customer pickup that is.
liquidmetal
What's the advantages of it?
It's completely different than SARA (What you're used to with an SA box in Austin). The guide is completely different, much better IMO. You can also customize everything a lot more than with SARA.
Also, you can actually search for shows! Something TWC has been WAY behind at in this region.
