Originally posted by sr
Mister HiFi, I am using 5 bnc (RGBHV) connection to a Sony VPH-G70 projector. I would speak to Dwin and LG technical support regarding the brightness issue.
I have spoken to LGE's technical support. They said all they could do was take the report because they had not run into this problem before. I use the same path for the LST3410A, an RCA DTC100 STB and a Motorola HDD200 HD decoder. I send the signal through a Zektor HDS-4 RGBHV switcher through the RGBHV input on a DWIN Transcanner which connects to a DWIN HD700 . The lRCA and Motorola operate perfectly.
Are you certain that the overall brightness does not change when the scene has large portions of the field get brighter or darker, e.g. a bright window or light or conversely, a dark wall or room? This only happens through that VGA connector. Everything is perfect through the S connection but then of course it is not in HD.
