AVS › AVS Forum › Video Components › Video Processors › New DVDO iScan HD
New DVDO iScan HD - Page 99
post #2941 of 2943
Originally Posted by Josh@dvdo
The HD, HD+, VP20 and VP30 allow the user to adjust the H and V sync polarities.
Josh,
I can't find any instruction on how to change the sync polarities in my HD manual. Please direct me to the correct section. Thanks!
Larry
post #2942 of 2943
Look in Output Setup under Sync. Page 11 in the HD manual. Separate polarities were introduced with the 1.31 firmware, so you need to read the addendum to see that information, but as long as you have the updated firmware the different polarities will be available to you under the SYNC option.
post #2943 of 2943
Thanks, I'll update my firmware.
Larry
  Back to Forum: Video Processors
This thread is locked
