Originally Posted by
earletp
Yes, there was an update to the A28 software.
original version was 78.44 - A28p0-2.0908.r4
now it's 78.53 - A28p0-4.1005.r-8
One of the first things I noticed is the guide is now back to two weeks again.
I suspect there are a bunch bug fixes too, but time will tell on that.
From the DSLreports Comcast forum (
http://www.dslreports.com/forum/r244...enance-Release):
I-Guide A28 Maintenance Release
An I-Guide A28 service pack (if you will call it that) is slowly being pushed out to Motorola headends.
Original I-Guide A28 version is:
The update A28 version is:
If you get the updated version, please feel free to respond if any of the major issues have been fixed. So far it's reported that the guide data goes out to 14 days, and the overall response is slightly improved.
Some bugs from the original A28 version to try to reproduce on the new update are:
-Intermittent blank-screen dropouts when using HDMI
-Longer HDMI handshake on TV power-up
-Occasional blank channel after HDMI handshake (guide works, but no channel audio/video until channel changed, then changed back)
-Occasional channel info pops up on the hour, sometimes not even for the current channel (possibly info from other tuner?)
-Favorites list resets at the top of the channel list when exiting info screens.
-If you are tuned to an SD channel that has an HD version available, a popup will appear for several seconds when a new HD program starts, even if you are actually watching an unrelated recording.
-When starting to play a recording, or after stopping playback, the audio may be muted. (Pause, then Play, will usually restore audio.)
-Sometimes after a tuner swap, or stopping a recording playback, the audio and video will continuously cycle on and off.
-VCR-style manual recordings (channel, start-time, end-time) that are set to repeat weekly will not record past midnight.
