Originally Posted by scrope
Hi, I have an hdtv in the bedroom hooked up via coax but without the cable box. Receive the local stations only. Yesterday I lost KOIN 6.1. Did a rescan with no success. Comcast blamed KOIN, so called the station and naturally they blamed Comcast and said mine was the only such call recently. I still receive 6.0 SD. Anyone else have this problem? Thanks.
I used to regularly lose KOIN HD on 6.1 with a similar direct connection like yours on Comcast cable (along with some of the other local HD feeds occassionally, but usually it was only KOIN). A full analog/digital channel rescan of my small HDTV in the workshop (located next to the main garage) would usually find them again but not always ..... again with KOIN being the worst offender (weakest signal strength).
I think some local channels may occassionally very in their signal strength (probably not intentionally) and if your direct digital cable signal strength to the HTDV is marginal (due to bad connectors or excessive splitters), your digital QAM tuner may lose them. I finally flipped a 3-way splitter configuration to have the direct signal for the workshop HDTV tuner now come off the higher -3.5dB output (rather than from one of the splitter's two -7dB outputs) and wiggled all my connectors. Problem solved ..... and all stations are still there as of this morning 6 months later.
I originally was feeding both of my two free Comcast DTA units (one for the main garage and one for the gym) from that spitter's single higher -3.5dB output and from one of it's two -7dB outputs. Then I remembered a Comcast tech once mentioning during my AnyRoom installation for the rest of my home that the little DTA units can handle a very weak digital singal (much better than most HDTV tuners or DVRs). So now both the main garage DTA and the gym DTA come from the splitter's two -7db outputs with no noticeable difference in PQ while the HDTV gets a stronger signal from the same splitter's -3.5dB output.
The Comcast tech apparently was correct in my case, as the workshop HDTV's QAM tuner, now seems to latch on and hold the HD digital channels consistently.
