Originally Posted by cjb101
I'm seeing something strange on channel 708 (NBC/KGW). Near the left edge of the screen, a couple inches up from the bottom, there's a lighter-colored spot. It's a box, an inch or two across; it almost looks like burn-in or IR (which is what I thought it was at first), but doesn't show up on any other channels or On Demand (including NBC shows). I see it when either viewing the channel directly or in DVR'ed shows. It's most noticeable when the scene is dark/black in this area.
Does anybody else notice the same thing? I'll try to get a picture that shows it...
Yes, don't worry. It is an artifact from the logo that KGW places near the bottom left corner of the screen. It goes away when the logo goes away. If you compare a DVR'd local broadcast to an ON DEMAND version of the same exact show (you can freeze the picture at the same exact spot) the logo will be gone and the spot will be gone with it. Nothing wrong with your TV.
