My receiver only has one mono LFE pre-out. I currently have a Y-adaptor at the end of the run plugging in to the sub L & R inputs.
I have a Velodyne DLS-4000 Sub (12"/200 Watt RMS). I previously had the CHT-15. The CHT-15 was very very loud, but was too boomy for my taste.
The DLS-4000 is much smoother and tighter, but not as loud (not as earth shaking as the CHT15 was).
What happens when I use a Y-Adapter to two separate subs? Will the signal be split in half? If so, I'm wondering if the AUTO on feature would not work since the subs may not detect a weaker signal....
I'm just wondering if the split signal would cancel out any gains from the second sub.
...or would the signal remain about the same (same voltage, lower impedance), and would I get almost double the LFE effect in the room?
