AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Roanoke, VA / Bluefield, WV - HDTV
Roanoke, VA / Bluefield, WV - HDTV - Page 202
post #6031 of 6116
Nope... It's 10:20 PM, listings end by 8:00 AM in the morning.
10, 21, and 38 continue on...
post #6032 of 6116
Originally Posted by Pete-N2 View Post
Nope... It's 10:20 PM, listings end by 8:00 AM in the morning...
Thanks, Back to the drawing board!
David
post #6033 of 6116
post #6034 of 6116
Is 15-2 gone yet?
- Trip
post #6035 of 6116
Originally Posted by Trip in VA View Post
Is 15-2 gone yet?
- Trip
Will be tomorrow. Got back logged on fixing other items today.
David
post #6036 of 6116
- Trip
post #6037 of 6116
Is 15-2 gone yet?
- Trip
Had if off on Friday for a little while. HD was at 14.5mbps. Also had one of the major cable companies have an issue, so back on for the weekend, we will try again this week.
David
post #6038 of 6116
Good luck, and let me know when it drops for good!
- Trip
post #6039 of 6116
- Trip
Will Do!
-David
post #6040 of 6116
So I looked at WBRA this morning and while the data for 15-2 is still being consumed and the PSIP is still there, I note the PMT is missing. For a lot of people, I'm guessing that means 15-2 is already gone.
- Trip
post #6041 of 6116
- Trip
That is correct. Getting the PSIP info removed and have established 14.5 Mbps for 15.1(HD).
-David
post #6042 of 6116
Any chance of having more than 12 hrs PSIP - it is really hard to schedule my recorder at 7 am when I can not see 8 pm.
Ch 10 27 and ION have 24 hours. It would really help after loosing 7 days with TVOS,
Thanks ,
Bernieoc with DTVPAL DVR over the air only
post #6043 of 6116
Thanks ,
I am working on it. According to our PSIP generator 24 hrs are showing on the screen, so I assumed it was sending it out. Not yet though, so I will continue working on it.
-David
post #6044 of 6116
Thanks ,
-David
Which system to do you guys use?
post #6045 of 6116
We are using the Trevini Guidebuilder for the PSIP and Protrack is what we use to traffic information.
-David
post #6046 of 6116
I get my Roanoke stations with OTA module on dish network satellite receiver pretty cool you can scan locals then dvr them. I Have 2 antennas one pointed toward North Carolina hooked to Hdtv. The other to OTA module the only way I've found to get HDTV reception in HD from 2 antennas. If you don't have satellite no help.
post #6047 of 6116
What's up with the picture on WSET today? Looking at the noon news and it looks like the picture came from a dot matrix printer! Especially noticeable on the 13 logo.
post #6048 of 6116
If they have a Harris NetVx HD encoder, the encoder card is dying.
post #6049 of 6116
I watched the 7:00 PM News on 13 last night. Everything looked fine.
post #6050 of 6116
I have turned on the NBA game tonight and the picture has the moiré effect. Looks terrible. I have also found that WSLS for sports is almost unwatchable due to pixilation.
post #6051 of 6116
What size screen and how far away are you? When I get close to the screen watching channel 13 I noticed what you're talking about. I wonder if they're transmitting a 16 by 9 SD picture tonight.
10. 1 is definitely a bit starved. It affect all programs not just sports the current program The Voice doesn't look too good either . If I understand correctly when the Richmond NBC station added a .3 they did away with the .2 program.
post #6052 of 6116
I am watching on a 106 inch screen with an Epson 5020ub projector. Sitting about 12 feet away.
post #6053 of 6116
Yeah with that system you probably see all the imperfections. SD must look pretty poor.
post #6054 of 6116
Yeah pixilation on Wsls is real bad on Sunday night football .So bad I turn to WXII.
post #6055 of 6116
And the COLOR late on the final game on SET?
post #6056 of 6116
post #6057 of 6116
Good luck up on the mountain, Alan!
http://www.rabbitears.info/tvdx/signal_graph/101B48F4/tuner1/WDBJ
- Trip
Yes, Good Luck, Alan!
-David
post #6058 of 6116
I get channel 3.8 and 3.9 when TVs are scanned, but no video. Is that real channels or local interference? Thanks
post #6059 of 6116
Those are channels that are used for datacasting. Basically sending information other than video and audio. They are embedded into our
signal stream.
David
Blue Ridge PBS
post #6060 of 6116
signal stream.
David
Blue Ridge PBS
Thanks David
