I have a modest 5.1 HT system with some Cambridge Audio MC200 speakers
http://www.cambridgesoundworks.com/s...item=k1pkm30zz
for my front speakers. They are supposed to be combined with their passive sub, Basscube 6S which are rated at 45-125Hz but I don't have them at present. As you can imagine the sound is a tad hollow since the main speakers bottom out at about 80Hz.
Assuming I get the Bass Cube to complement the fronts, do I then need an additional sub for the .1 signal from my 5.1 system. Alternatively if I got a more massive sub that went down to say 30Hz to match with the MC200's, what would I do with the .1 signal? Is there a way to route that .1 signal out to the 5 other channels?
Not sure if I could have two subs in the room - wife factor:-)
