AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Do I need a better subwoofer cable?
post #1 of 8
I have a Sony SA-WM500 sub and right now I'm just using the dinky little wire that came with it to connect it to my Yamaha RXV-440 receiver. Will I notice a difference with a better cable?
post #2 of 8
no
post #3 of 8
yes you will, NEVER use OEM cables that come with your stuff.
just buy any quality RCA Audio cable and it'll work fine, and you can tell a difference IMO, you can sometimes notice hum with a crap cable on a sub.
post #4 of 8
Hmmm. One "no" and one "yes". Just to round out the offering, I say, "maybe."
My recent experience ...
I bought a set of Onix Rockets, including the UFW-10 sub. I had an old crappy RCA sitting around for the sub cable and used it. Seemed to work well for music but when I turned on the TV and cranked the sound, the picture grossly distorted each time a bass hit happened.
Bought a good quality Acoustic Research cable (~$50 list, got mine for ~$30 from accessories4less.com) and the problem disappeared.
Seems that my low-quality sub cable was "leaking" RFI and messing with the TV.
So, if you are having a problem like mine or are getting hum (or other noise/distortion) in the subwoofer, a better sub cable may help. Otherwise, you may be wasting your money.
Of course, it is also possible that you are experiencing no obvious sonic/visual problems but the sub signal is being otherwise degraded in quantity or quality and a better sub cable would help. Before spending money on a better cable, try borrowing one from a friend.
Rule #1 for upgrading: If you can't tell the difference, don't spend the money.
Cheers,
Bill
post #5 of 8
Try this inexpensive one - it will sound a little better too. The stock is less than a dollar one. and you will be rewarded to upgrade - but don't spend over 5-7% on them. You can waste money on expensive cables.
post #6 of 8
post #7 of 8
Many folks recommend using RG6 coax for subwoofer cables, especially if you have long runs. You can then get "F to RCA" adapter for the ends and you are set.
I myself bought some high quality flexible Belden coax and put a gold-plated compression RCA connector on each end. Cost me $14 for a 40' sub cable.
post #8 of 8
Here's a link to a connector you can use with the RG6 coax.
http://www.partsexpress.com/pe/pshow...1-1060&ctab=14
This thread is locked
