Originally posted by audioguy DrSpike69:
You use the B4 for movies with 3 ports blocked ??? |
It depends on the movie really. I usually have it with 1 or 2 ports plugged. But some movies have some very low bass, so I plug the 3rd. I also play with port tuning with different movies to see what is different if anything. That gives me a chance to recalibrate my system too....LOL!!! :D
So to answer your question, yes, yes I do. (sometimes...lol)
For a lot of music I tend to use 1 or none. Except for some classical and organ music. Then I use 3.
Really in my room I have no problems with using 3 plugs and getting reference level SPLs (actually I can get the system calibrated in my room to the same SPLs with any port configuration.) I just like to play too much...lol :D Plus, I think some material 'sounds' better with different tunings. Of course it could all be in my head because I like to play... :D
I guess if I didn't like to play so much, I'd just leave in 3. Or 2.... :D
{My room is 17L X 20W X 7H that opens into a 13L X 22W X 7H room and a 14L X 22W X 14H room, there is 1 opening in the front of my HT room that leads to these 2 rooms which are basically fully open to each other with a partial wall that is open in the center (a big hole in the wall basically). Also a staircase to the second floor is off of the HT room. Over 8000 cu-ft total, effective room size is probably more like 6000 cu-ft, maybe less.
I power the sub with a Peavey GPS 3500 bridged. The sub is also 'corner loaded' with the ports firing into the wall.}
