Originally Posted by
spiff72
Thanks Abby...
Just curious - now that SDV has been implemented in my area, does this mean that the only devices that fully support CableCard are Tivo's? (Since they are the only device that allows the use of a Tuning Adapter?)
No, you can use other devices, and Tivo is NOT the only one that supports a TA.
spiff72
Does this mean that a computer with a cablecard-equipped tuner or a TV with a cablecard slot will not support all of the available channels on our subscribed tier? And is there a way to know which channels are affected by this lack of support for the tuning adapter?
Jeff
I am currently using a silicondust HD Prime and get all channels I am supposed to. There is no limitation unless you use a HTPC frontend other than MCE, then you wont get the copy-once channels. So for me, in SageTV, I dont get the premium channels. If you use MC7, you get everything including premiums.
You wont get VOD/PPV on
any cable card device though.
One other thing, Charter will send you a CC (and probably the TA) free of charge via FEDEX 3-day service.
Kirby
