I think I may be seeing burn in my my display (Panasonic 37" 5th gen).
I hadn't noticed any, but I thought I'd have a close look. So I fired up a calibration DVD and played grey and coloured fields and squinted. (Its difficult to see anything with all the after images you get.) Then I got up close and squinted. I thought I could see faint shadows in blue and green, but not red. The shadows are horizontal lines about 1/6 the way down the screen and 1" from the bottom.
I couldn't think what caused them. The top is in about the right place for the top of a 2.35:1 DVD (Component in 16:9 mode) and the bottom is in about the right place for a 1.66:1 TV image (S-Video in just mode). I don't watch much of either, and why only the top or bottom.
I think it actually corresponds to the top and bottom bright white border of the TiVo now playing screen. I must say I've worried a bit about that, its a very bright line and I spend quite a bit of time in that screen. I've had the TiVo for 13 months now.
I'm going to let it rest overnight and see if the shadow goes away, and just to be safe I adjusted the image position a bit to move the border to other pixels.
Any other suggestions?
How does everyone else check for burn in? Does everyone else check for burn in?
Just to be clear, I hadn't noticed it, its not visible in normal viewing, its only there if I go looking carefully for it.
