Originally Posted by
DonInTn
And they are full of crap.. the reason you can't get them is because someone at Comcast screwed up the psip info for those two channels over the weekend. They are still there.. they're just transmitting wrong info which is confusing your tv's scanner ability to tune them.
Of course the only tech people that you can talk to at Comcast are about user-end problems... this is a headend problem.. and I have no clue how you go about finding out who is responsible for this stuff.. and if they can fix it. It'd guess if you could ever get to the right person, it'd take all of about 5 seconds on their end to update a two entries in the channel map database to fix this problem.
Thanks Don. I hope you don't mind- I used your explanation in an online chat with a Comcast rep.
Transcript of the conversation (ok, I added the emoticons, or whatever they are called):
user Paul_ has entered room
Paul(Mon Aug 17 2009 19:46:59 GMT-0400 (Eastern Daylight Time))>
I cannot get ESPN, ESPN2 on my TV with built in digital tuner (no cable box). Why not?
analyst Aaron.33918 has entered room
Aaron.33918(Mon Aug 17 2009 19:47:07 GMT-0400 (Eastern Daylight Time))>
Hello Paul_, Thank you for contacting Comcast Live Chat Support. My name is Aaron.33918. Please give me one moment to review your information.
Aaron.33918(Mon Aug 17 2009 19:47:09 GMT-0400 (Eastern Daylight Time))>
I am here to make your day better by providing world class customer service.
Aaron.33918(Mon Aug 17 2009 19:47:34 GMT-0400 (Eastern Daylight Time))>
I understand that you have an inquiry about not being able to get the ESPN and ESPN2, right?
Paul_(Mon Aug 17 2009 19:48:09 GMT-0400 (Eastern Daylight Time))>
I get all the digital channels except ESPN, ESPN. Why are those the only 2 channels Comcast blocks from reception by TVs with built in digital tuners?
Paul_(Mon Aug 17 2009 19:48:25 GMT-0400 (Eastern Daylight Time))>
edit: ESPN, ESPN2
Aaron.33918(Mon Aug 17 2009 19:49:06 GMT-0400 (Eastern Daylight Time))>
I understand that this may have caused you inconvenience. I would be glad to check on this for you.
Aaron.33918(Mon Aug 17 2009 19:49:08 GMT-0400 (Eastern Daylight Time))>
Do you happen to have your account number?
Paul_(Mon Aug 17 2009 19:49:11 GMT-0400 (Eastern Daylight Time))>
xxxxxxxxxx
Aaron.33918(Mon Aug 17 2009 19:49:59 GMT-0400 (Eastern Daylight Time))>
Thank you.
Aaron.33918(Mon Aug 17 2009 19:50:01 GMT-0400 (Eastern Daylight Time))>
At Comcast we do value our customer security and privacy. For account verification, may I please have the last four digits of the Social Security Number associated with the account?
Paul_(Mon Aug 17 2009 19:50:06 GMT-0400 (Eastern Daylight Time))>
xxxx
Aaron.33918(Mon Aug 17 2009 19:50:24 GMT-0400 (Eastern Daylight Time))>
Thank you for that information.
Aaron.33918(Mon Aug 17 2009 19:50:32 GMT-0400 (Eastern Daylight Time))>
Paul, your account number is xxxxxxxxxxxx, okay?
Aaron.33918(Mon Aug 17 2009 19:50:34 GMT-0400 (Eastern Daylight Time))>
Please give me one to two minutes to check this for you.
Aaron.33918(Mon Aug 17 2009 19:51:39 GMT-0400 (Eastern Daylight Time))>
Thank you for patiently waiting.
Aaron.33918(Mon Aug 17 2009 19:52:30 GMT-0400 (Eastern Daylight Time))>
Paul, since you do not have a box connected on the TV where you are unable to access ESPN and ESPN2, we may need to send a technician to check this.
Paul_(Mon Aug 17 2009 19:53:12 GMT-0400 (Eastern Daylight Time))>
It makes no sense that only those 2 channels do not come in. I get every other digital channel.
Aaron.33918(Mon Aug 17 2009 19:54:40 GMT-0400 (Eastern Daylight Time))>
I understand how frustrating this has been for you. The codes on the account are correct but you are having problems in access the two channels. That is why we will be sending out a technician to get it fixed.
Paul_(Mon Aug 17 2009 19:54:56 GMT-0400 (Eastern Daylight Time))>
I have asked 3 different representatives from Comcast, including driving to the local office and talking face to face there and the only answer I got was "you have to use a digital box to get those."
Aaron.33918(Mon Aug 17 2009 19:55:10 GMT-0400 (Eastern Daylight Time))>
The earliest possible date and time is on 8/19, around 11 am until 2 pm. Will this be okay with you?
Paul_(Mon Aug 17 2009 19:56:19 GMT-0400 (Eastern Daylight Time))>
No- I am considering moving my business to Dish Network, so I do not want to schedule an appointment. I'm just disappointed that nobody can give me an answer. I'm not the only one with this problem, so it's not something a technician will be able to fix.
Aaron.33918(Mon Aug 17 2009 19:58:31 GMT-0400 (Eastern Daylight Time))>
I totally understand the frustration this has caused you, Paul. Actually, the technician is a perfect person to verify if there is a problem with the connection that is why the transmission of signal for ESPN and ESPN2 cannot go through. But unless we send one to your household, we will not be able to clearly identify the problem and have it fixed.
Paul_(Mon Aug 17 2009 19:59:42 GMT-0400 (Eastern Daylight Time))>
In a nutshell, here is the answer to the problem. It's not a problem on my end that a technician sent to my house will be able to fix:
analyst Aaron.33918 has been temporarily disconnected. Please wait while the analyst attempts to reconnect.
Aaron.33918(Mon Aug 17 2009 20:03:03 GMT-0400 (Eastern Daylight Time))>
I understand the frustration this has caused you. That is why we may send some one out to check why the two channels are not working. The earliest possible date and time is on 8/19, from 11 am to 2 pm.
Aaron.33918(Mon Aug 17 2009 20:03:04 GMT-0400 (Eastern Daylight Time))>
Shall we go ahead and get this processed for you?
Paul_(Mon Aug 17 2009 20:03:14 GMT-0400 (Eastern Daylight Time))>
Did you read my last post?
Aaron.33918(Mon Aug 17 2009 20:05:12 GMT-0400 (Eastern Daylight Time))>
Yes. I read it, Paul. You may contact the local office at 18002662278 to have direct connection with the headend to correct it.
Aaron.33918(Mon Aug 17 2009 20:05:51 GMT-0400 (Eastern Daylight Time))>
As much as I would like to do it, I can only set up an appointment for it to be checked.
Aaron.33918(Mon Aug 17 2009 20:06:18 GMT-0400 (Eastern Daylight Time))>
Paul, what we did today is noted the account about the problem you are having with the ESPN and ESPN2 channels.
Aaron.33918(Mon Aug 17 2009 20:06:20 GMT-0400 (Eastern Daylight Time))>
Is there anything else I could assist you with today?
Paul_(Mon Aug 17 2009 20:06:37 GMT-0400 (Eastern Daylight Time))>
That's ok, I will attempt to contact the local office and ask for someone "with the headend", as you say.
Paul_(Mon Aug 17 2009 20:06:39 GMT-0400 (Eastern Daylight Time))>
Thank you
Aaron.33918(Mon Aug 17 2009 20:06:55 GMT-0400 (Eastern Daylight Time))>
You are most welcome.
Aaron.33918(Mon Aug 17 2009 20:06:58 GMT-0400 (Eastern Daylight Time))>
I will greatly appreciate it, if you take time to answer the 3 pop-up questions after clicking the end session button. Thank you so much.
Aaron.33918(Mon Aug 17 2009 20:06:59 GMT-0400 (Eastern Daylight Time))>
If you need assistance in the future, please do not hesitate to contact us through Live Chat or E-Mail (available 24 hours a day, 7 days a week). Comcast also offers excellent FAQ and Help forums located at
www.comcast.com to help you reach a resolution independently.
Thank you for contacting Comcast! We appreciate your business!
Aaron.33918(Mon Aug 17 2009 20:07:00 GMT-0400 (Eastern Daylight Time))>
Please take care.
Aaron.33918(Mon Aug 17 2009 20:07:03 GMT-0400 (Eastern Daylight Time))>
Have a goodnight!
