Originally Posted by
frogwaterÂ
If this set-up works, then it's on to my next concern: figuring out how to set up my extra PC to work as a DVR. If you (or anyone else reading) have any suggestions (software, etc.) in this area, they are more than welcome!!! And thanks in advance!
Myself, I was thinking of getting this or something similar if I find that I still want a DVR for OTA.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116036
Dual tuner so you can one of the following combos
- Watch two shows at once
- Watch one show while recording another
- Record two shows at once
Though if you only want a single tuner, you'll save a little bit of money. It comes with its own software. Just not sure how good it is. I found a 3rd party app that looked really good that works with this type hardware. If I find it I'll post back with a link.
Now I just need to find a way to have a TV Guide for the stations that I have. Might have to make an app for that (unless one exists) that can pull the data off network websites. I now have now idea what is coming on or going to be on which sorta is a bummer.
