I'm having issues receiving DTV in my apt using a Zenith HDV420 STB and Silver Sensor antenna. I do get an acceptable signal if I place the antenna in my bathroom, which is about 24 feet from the STB/TV. I found that the metallic siding on my apartment building must have been causing a significant signal loss. The bathroom is the closest room to the outside (with no other apartments on the other side). Also, the outside of the bathroom is stucco, not metallic siding. The major clue hit me when I ran a 50' length of coax cable from the STB to the outside, just to see if I could get a signal. When I did this, I got a very strong signal on all 3 channels.
I'm on the first floor of a four story apt. building, and my patio (the only place I could legally put an outdoor antenna) faces AWAY from the local transmitter sites.
Cable HDTV is not an option for me at this time.
Perhaps someone with a similar problem has a solution or suggestion.
But if there's a nearby tall building, water tower, bridge etc. within site of your patio, you may be able to get a "bounced" signal by aiming a directional antenna (like the Silver Sensor) at the building.
