AVS › AVS Forum › HDTV › Local HDTV Info and Reception › New Orleans, LA - HDTV
New Orleans, LA - HDTV - Page 151
post #4501 of 8177
Never got CST anyway. I moved from New Hampshire (Boston Locals)
I now get Fox Sports South and SportSouth ..... I couldn't care less about either one... or CST.
post #4502 of 8177
Originally Posted by TiVoFishMan View Post
WGNO-DT and WNOL-DT have been on their new shared transmitter (physical channel 15) for about a week now, and yesterday they were dropped from WPXL's transmitter (physical channel 50).
The "downloaded mapping" that comes from DirecTV to map the OTA tuner on my HR20's switched to the new physical 15 for both channels within 48 hours of them going live. I also have reason to suspect that DirecTV re-tuned and re-aimed their local receiver, that receives WGNO-DT for retransmission via satellite, to the new transmitter within 48 hours or so of it going live.
Since the new channel 15 transmitter came on line, I have not noticed one single audio glitch on WGNO-DT. Not one!
A few months ago, I managed to get a message through to their engineering staff about this issue and was told that they had some issues with their STL that they were working out.
Thankfully, it would seem those "issues" did not carry over to their new transmitter.
Now, if they'd only go DD 5.1....
Fishman...I also have an HR20...how can you tell that the OTA tuner on the HR20 switched to the new physical 15? Just curious?
Also, my wife and I watched Extreme Makeover - Home Edition last night, and the audio was much better than it was. There were, however, 2 or 3 instances where the audio dropped for about a second or two, but it was nothing like before. So yes, progress is being made!
Cheers,
John
post #4503 of 8177
By signal strength. There is now a distinct difference in the signal strength shown on the meters between 26-1 and 38-1 (which are the same as each other) and 49-*, which are all the same as each other, but different from 26-1 and 38-1.
Besides, at this point in time, if it didn't, I'd be seeing Qubo instead of WGNO and ION Life instead of WNOL.
post #4504 of 8177
Originally Posted by NOHDjunkie View Post
The Birmingham locals look fine so far.
NBC Golf looks great (No discernible difference from WDSU OTA)
Nascar on FOX looks good (No discernible difference from WVUE OTA)
College Bball on CBS looks as good as WWL OTA
No thing to compare on ABC yet
Seem like a good move. Hopefully Dish will leave these locals alone on 119 spotbeam until NO locals get on the dish.
Thanks for the update Jim, good to know we have backup with Dish as they are moving CONUS beams to spots.
post #4505 of 8177
I have a feeling the Boston locals will be going spotbeam sooner rather than later, thus the move.
Painless move via the Dish Live Chat.
post #4506 of 8177
It looks like WHNO has stopped multicasting WDSU on channel 20. 6-1 is no longer duplicated on the TV tuner and 6-1 is a black screen on the HR20. I'm sure 6-1 is still mapped to 20. I'll call in and let you know what they tell me.
EDIT: DIRECTV said a re-download of the local channel database (Re-run Initial Off Air Setup) is the only fix as the station and not DIRECTV supplies the physical channel number. I ran the setup and the problem was corrected. I am now getting a better signal on 6-1 (100%) than 20-1 (96%).
post #4507 of 8177
For whatever reason, your HR20 may have needed to be forced to refresh its local channel mapping (not particularly surprising), but you were not given accurate information from the DirecTV CSR (also, not particularly surprising), as that info most definately comes from the DirecTV satellite stream, and is supposed to update in real-time. But, as you saw, doesn't always.
Both of my HR20s moved their mapping of 26-1 and 38-1 from physical frequency 50 to frequency 15 without me having to re-run anything or reboot. One of my HR20s moved 6-1 to physical 43 (from 21) within hours after channel 6 moved without me having to do anything. The other one failed to do so, and still failed to do so after a reboot, days later. I'll check and see if its moved today, and if not, I'll try re-running the set up on it.
post #4508 of 8177
I know this has been covered elsewhere, but I have a quick question for my neighbor that has Cox Cable [I have Directv]
They bought a new HDTV, and have the cable connected directly to the coax input on the TV [no cox box]. Haven't I read here that they should be able to get the locals [and maybe other channels] for free in HD on some other channel number? How is this done? Do you have to know what the channel numbers are, and direct tune to the station?
Thanks for the help, guys
Cheers,
John
post #4509 of 8177
Frank,
May I ask what (Make, Model) STB you're using to receive these QAM channels? My LG 3410A can't find any QAM signals on these frequencies.
Ben
post #4510 of 8177
Cheers,
John
Only if they have a QAM tuner built into the TV. Have them Read The Manual and see if their set has one.
If yes doing a channel scan should bring up the available locals and sometimes pay channels and other HD channels.
Metairie clear QAM channels from Franks post a couple pages back;
81-2 WDSU
81-3 PBS
82-1 WWL
83-3 WDSU Weather
126-2 CW
126-5 ABC
127-1 WUPL
post #4511 of 8177
81-2 WDSU
81-3 PBS
82-1 WWL
83-3 WDSU Weather
126-2 CW
126-5 ABC
127-1 WUPL
Thanks, Jim. I will get their manual to see if they have QAM tuner installed. I would think so since they just purchased? Will report back what I find out.
Thanks for the help.
Cheers,
John
post #4512 of 8177
The CSR (in the technical department) acknowledged that the data was coming from DIRECTV via sat, but insisted that they have no control over that data, that it was being passed through a service directly from the stations and that even though I knew that the problem was switching the physical channel from 21 to 43, that there was nothing they could do about it. She insisted that that data came , through them, from the station.
post #4513 of 8177
Hey Everyone. Thanks for the help! I figured out what happened. I guess Cox Communication changed the type of signal or something. I'm not familiar with this stuff, but after someone said that they are still receiving the Clear QAM signals I figured maybe something was wrong on my end. So I played with some settings and sure enough on the OnAir GT, I changed standard QAM to IRC and boom all my channels came back. I don't know what IRC means, but I'm happy!
post #4514 of 8177
That I totally agree with.
The point I was making is that you don't always have to re-run OTA setup when the mapping changes.
Here's an update on my HR20's:
The one in the living room fully updated itself without me having to do anything. I've never re-run OTA setup. It hasn't rebooted or updated its firmware version in months. It's plugged into an UPS. It tunes to the correct frequency for all OTA channels.
The one in the bedroom was still trying to tune to 21.2 for 6-1. I re-ran OTA setup, and that fixed 6-1 but 38-1 disappeared! I re-ran OTA setup again. Still no 38-1 (38-1 is still fine in the living room.) I'll wait a day or two (perhaps there's currently a glitch in the data on the sats) and re-run again.
post #4515 of 8177
............ I will get their manual to see if they have QAM tuner installed. I would think so since they just purchased? .............................
Maybe, maybe not. One of the ways that HDTV's have gotten cheaper lately is that the manufacturers decide to leave out certain features . . . . .
post #4516 of 8177
My HR20 didn't have the updated info for WDSU, so I reran the OTA antenna setup. WDSU showed up, 38.1 is still there, and WGNO is now listed as 49.3 but is where it should be numerically between 20.1 and 38.1 in the guide (strange).
post #4517 of 8177
Originally Posted by Ben Hardy View Post
Frank,
Ben
I don't use a STB. I connect directly to my Mitsubishi 56 in DLP TV which is about 2 1/2 years old. One connection handles both analog and QAM. Another connection handles OTA.
Frank
Clarification1: These are not frequencies; these are channel numbers.
Clarification2: I do have a Cox STB which connects via component but I seldom use it.
post #4518 of 8177
Cheers,
John
New TV's don't necessarily have QAM tuners, They are only required to have ATSC tuners.
post #4519 of 8177
126-2 CW
126-5 ABC
127-1 WUPL
I am having trouble tuning into anything higher than 122-1 with my MyHD card on my PC. Any tips on how to get it to find these higher channels? Digi?
post #4520 of 8177
The TV did have a QAM tuner....and she was able to pick up all the channels listed above. Would not have known about any of this if I had not read all the good info on this forum.
So thanks to all and cheers,
John
post #4521 of 8177
This kind of thing, specifically that different HR20's are behaving differently with respect to the New Orleans channel mapping suggests to me that they have a mixture of both old and new mapping data in the satellite stream (some of which is contradictory) and whatever data the HR20 happens to see in the stream "first" it accepts, and then ignores contradictions after that.
So, each time you re-run Antenna Setup, a crap-shoot as to which data it will latch onto occurs.
Hopefully they'll have it straighted out soon.
(And, they need to add 8-2 and 6-2 to the OTA mapping too!!)
post #4522 of 8177
New Direct TV HD channels starting tomorrow (Wednesday April 2nd).
207 - ESPN News HD
290 - Disney HD
292 - Toon Disney
http://www.dbstalk.com/showthread.php?t=124497
post #4523 of 8177
Originally Posted by hockey2112 View Post
126-2 CW
126-5 ABC
127-1 WUPL
Can you not lock them? Cox used to go up to 122 over here but I see they have some carriers up to 129 now. I have no issue locking on 129. It's not viewable though since it is encrypted.
Make sure you have the latest version software for the MyHD.
post #4524 of 8177
Not sure if this is in the right thread but here goes. As I understand it (please correct me if I'm wrong on this), D* transmits most of their HD signals over one satellite. I want to tweek my 5 lnb dish to that satellite as more HD stuff comes online. It seems like the HD product goes off well before the SD stuff in a moderate/heavy rain.
We're experiencing a continuous moderate rainfall in the Slidell area right now and I can get the Encore SD channels OK but the Starz HD channels are digitized out. Am I heading in the right direction with this? If D* in fact does transmit most HD signals over one satellite, which one is it?
post #4525 of 8177
D10 at the 102.8 position is where the new KA national HD comes from.
Spaceway 1 and Spaceway 2 are for HD LiL's.
post #4526 of 8177
The New Orleans locals have been moved to D10 and all but a handful of the HD CONUS channels are also coming from D10. You want all of your signal readings for 103(c) to read above 90 ideally. Even if you are peaked perfectly, the D10 Ka signal will drop before the Ku sats in heavy rain. I lost the locals for a couple of minutes between 5:30 and 6:00 this afternoon. Once your dish is peaked, there isn't much else to do.
Here are the signals I'm getting right now on D10/S1:
103 (c)
91 92 93 95 92 95 94 95
95 95 96 96 96 96 na na
99 na na na na 99 na na
na na na na na na na na
103 (s)
00 00 00 00 00 00 na na
na na na na na na 00 00
98 00 00 00 96 00 00 00
post #4527 of 8177
sjv,
If your signals look like sore-bluto's above, your dish is probably fine.
If those two non-zero readings on 103(s) or any of the readings on 103(c) are below 90, it's probably well worth peaking your dish.
It's just a sad fact that Ka (the band DirecTV transmits most of their HD channels on) is more susceptible to rain fade than Ku (DirecTV's older sats).
post #4528 of 8177
103 (c)
103 (s)
sjv,
Fellas, thanks so much for those replys......I didn't have a clue as to which bird had the HD stuff. Thanks to ya'll, I now know it's 103. Now for the biggie: if I can't do this tweeking myself (a distinct possibility), who in the area would have the expertise and proper equipment and you would recommend to do this tweeking. I'm in the Slidell area if that is a factor. So we don't ruffle any feathers, pleaase PM me with your recommendations.
Many thanks.
post #4529 of 8177
Many thanks.
I downloaded these channel / sat-transponder tables from dbstalk.com yesterday. You may find them helpful. I cannot vouch for their accuracy.
tpntochl_080224.pdf 40.9072265625k . file
chltotpn_080224.pdf 31.2353515625k . file
post #4530 of 8177
26.1 and 38.1 have been added to the channel lineup and pointed to the correct frequency, as well as 6.1. Guide data for 49.2 and 49.3 have also been added. The channels are out of order as 26.1 and 38.1 were at the bottom of the list. To get this, I did the following: restart your receiver, and at the "Welcome. Your DirecTV Receiver is starting up", hit 0-2-4-6-8 on the remote. This checks to see if you have the latest firmware; if so, the startup process continues; if not, the receiver will download the latest firmware from the satellite. Then go to SAT & ANT and redo the antenna setup. It should work. If not, add Baton Rouge local stations to the secondary market and remove 2-9-27-33-44, that's how 26.1 and 38.1 appeared in my setup. 6.2 and 8.2 are still missing from the lineup.
Greg
