AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Lafayette, LA / Beaumont, TX / Lake Charles, LA - HDTV
Lafayette, LA / Beaumont, TX / Lake Charles, LA - HDTV - Page 234
post #6991 of 9760
Originally Posted by BPTTV View Post
64.1/RF43 is SW of Beaumont....the RF36 is north of Orange...both carry the same programming...congrats on grabbing it.
Thanks. I'm a bit surprised about the "HD" in the PSIP. Is it actually an HD station? Or maybe at the time it came in there was network HD programming?
post #6992 of 9760
Originally Posted by OTAhead View Post
Wow, that is quite a snag. I was getting KFAM-LP channel 14 and LP channel 51 from LC the last couple of days. 51, a TBN affiliate, was coming in at about an 8.5 on scale of 10. Never got it that clear before.
Yeah Friday night that same ch 14 came in as XHOR-14 in Matamoros. 442 miles. It was a very good tropo night on the gulf coast.
post #6993 of 9760
Holdover from when 36 digital and 64 analog was FOX.....ANY digital station is HD capable....if they have the correct equipment...but they cannot generate local HD programming; only any network programing passed on.
post #6994 of 9760
Analog 2 from Matamoros was also coming in...107.1, the LPFM in Port Arthur was covered up by a stereo Spanish station...not sure where it was from..and I heard what sounded like a network audio feed on 87.70 (no stereo and it was in Spanish so likely an analog 6 in Mexico)..FOX 8 (RF??) out of NO was in last night!
post #6995 of 9760
Yep Fox 8.1 RF 8 Not sure where you're from, but probably a nice catch.
post #6996 of 9760
BPT area....thought I would have gotten KUHT instead, but the antenna was pointed ENE for Lake Charles.....Some channels got Houston, others got La...
Best catch so far digital was a MS station...best analog was 4 out of Washington DC!!! Had a 2 analog during nightlight but not sure where it was from...
post #6997 of 9760
DC! WoW! Had to be E Skip for that one right? Got your antenna up pretty high?
post #6998 of 9760
I believe WVUE is still transmitting on RF 8 and RF 29. They both map as 8.x.
post #6999 of 9760
2nd night in a row that I have been getting audio from KCOL 92.5 over analog channel 25...
Talk about weird.
post #7000 of 9760
Talk about weird.
Tropo plays hell with FM band harmonics sometimes.
post #7001 of 9760
Daytime.....antenna was only 20ft high....when the band is open, almost anything will do.....
(Note to OTAhead...could not get IE to open the site here...switched to Firefox)
post #7002 of 9760
Given the UHF band was better, likely was 29 I was seeing...didnt think of checking it on the 722 local list
post #7003 of 9760
band opening tonight...I have seen a lot of the Houston as well as La DTVs...(20/19, 22/23, 14/24, 26, 39/38 and 61's digitals) and even puny KLFY 10.1!!
I did a rescan monday night as well and was able to pickup all of New Orleans stations very clear, but still not KLFY?.. It was good to watch all the saints coverage.. It'd be nice to have this kind of reception every night! Are you listening mother nature..
I'd been putting this off for months, but super bowl on cbs coming up, so 2 weeks ago i got in a new high gain yagi VHF antenna i hooked up along with my current db8 antenna and used the cm 7777 combiner and amp.. Now i still can't get klfy, but i get alexandria's cbs at about 70-80% and everything else at or near 100% Only katc comes in under 50 at times..
post #7004 of 9760
[quote=Retro3;18019139]
I get both CBS Alexandria and Lafayette and believe me you don't want to watch NFL on Alexandria 5.2. Lots of fast motion artifacts on screen. Someone here once explained why, dont remember the reason.
post #7005 of 9760
Probably because the Alexandria station has both a NBC and a CBS, so they basically have half the bandwidth (19.x Mbps) to give each channel. KLFY has just one channel, so they can encode CBS at a much higher rate.
post #7006 of 9760
Of course with statmuxxing, they can manage their bandwidth between the 2 channels more efficiently. I am not sure if they are doing this are not, but even if they are it still will only help so much.
post #7007 of 9760
Lipstick on a pig comment comes to mind
post #7008 of 9760
[quote=mp11;18020249]
Yes, i already knew there was a bandwidth issue and watched it the last 2 weeks, but it'll have to do for now.. I'll probably either get a taller mast or a much bigger antenna overall to remedy the problem unless klfy increases power soon... I have directv and last year they put the super bowl game on a rarely used channel as a backup and in hd i believe, so i'll check for that as well. I'll do a rescan for KLFY just before the game and maybe some antenna adjustments to see what happens as well..
On another note, was picking up WEAR 3.1 out of pensacola last night for about 30 minutes around 11pm.
post #7009 of 9760
KFDM has applied for a channel change. To what channel, I don't know. I'll let you know when I wake up in the morning.
- Trip
post #7010 of 9760
Oh wow, that is fantastic! Without looking at anything, I am going to guess either channel 18 for themselves, or channel 50.
I have been looking for something from them ever since they filed for the STA extension. It was only for 6 months, and they stated in the app for the STA that they needed the extra time to "assess the situation". This is toally cool, and I wish them all the luck in getting it granted and up and running.
I can't wait to see what channel they applied for.
Don't guess it will be on in time for the Super Bowl, huh??? LOL
Trip, please let us know what the ERP will be also, OK? And thanks for the heads up.
post #7011 of 9760
I was literally on my way to check RabbitEars to figure out what channel it was when RabbitEars went down. So, I'll let you know as soon as I can get to my website.
- Trip
post #7012 of 9760
- Trip
25 @ 350k omni
post #7013 of 9760
Gah, I just got it and then you beat me to it with your insider info!
- Trip
post #7014 of 9760
Originally Posted by hdtv6 View Post
25 @ 350k omni
first question that comes to mind, is why 25 and not 18? I seems like on 18 the ERP could go even higher, and possibly up to 1,000 KW?
But not to look a gift horse in the mouth, I hope it is granted soon, I know the residents of LC and Sulphur will be delighted once it is on, as well I guess those that live to the north.
post #7015 of 9760
Well, so much for my insight...
post #7016 of 9760
Because our consulting engineer says it is the better channel.
R
post #7017 of 9760
That would be a dream come true, eh? KFDM at 1000kw on a top mount omni! But I'm sure the Sulphur folks would take the 350k on the omni just as well.
KLFY is still working for most Lake Charles folks.
post #7018 of 9760
Channel 18 would have problems with the land-mobile stuff in Houston.
- Trip
post #7019 of 9760
Ah, OK. That is why 18 would have worked for KLTL but not KFDM. Gotcha.
post #7020 of 9760
- Trip
A null toward Houston on 18 with 1MW ERP would have worked....not much on the LMR channels there anymore.
