AVS › AVS Forum › Display Devices › Rear Projection Units › Sony WS510/WS550 Owners Thread
Sony WS510/WS550 Owners Thread - Page 7
post #181 of 819
Originally posted by Hoonyo
Hey, thanks for those other options! I noticed HPOS (probably what I need to adjust) is in two categories: 215OD-2 and OSD. What exactly is the difference? Also, will I need to go into each Video mode from 1-7 and adjust it for each?
It seems like HPOS has only one setting for all wide modes. HSIZ has two settings, one for wide zoom, one for everything else (zoom, full/norm, 1080i).
The ones under OSD is used for on screen display.
post #182 of 819
Thanks for the info guys. I've just about eliminated all the underscan and overscan. There's a little part on the top right corner that seems a little off, though. It's like a very thin triangle of black.
post #183 of 819
If you did change HPOS, HSIZ, etc, you need to re-register Flash Focus. Otherwise convergence will be off if you use FF to do convergence.
post #184 of 819
What do you mean re-register?
post #185 of 819
I just took off my glare screen, but ummm... I feel stupid for asking but I just wanted to make sure...
I was supposed to take off the outer most screen out of the three, right? The one that is clear and highly reflective? The other two are not as clear and the outer screen is now "corrugated."
post #186 of 819
Yes, that is correct.
The other 2 layers are the Lenticular ane Fresnal, they must be used.
post #187 of 819
Does anyone know of a code that will allow a Sony Televison Remote to operate the Toshiba DST 3100 Direct TV, HD receiver?
The Sony codes in their manuals show 806 / 807, these will not control the DST3100.
post #188 of 819
Do a search in this thread, you will see how to re-register FF correctly.
post #189 of 819
I heard you can call Sony to get the correct code.
post #190 of 819
Earlier in this thread, there was a link for tweaks to Sony RP TV's. Are these compatible with a KP51WS510?
post #191 of 819
post #192 of 819
post #193 of 819
Yes, it works with ws510.
post #194 of 819
Originally posted by monsta11
email me at purrball@xtra.co.nz
Just a suggestion, if yours is the 23MB pdf file, you might want to send out the first 175 pages only, since after that it is just user manual in different languages and most people can't receive attachment larger than 10 MB.
post #195 of 819
Hi,
I am a newbie here...
I am in the market for this SONY KP-51WS510. I like to setup
my HP Media Center PC to it. I know there is a DVI input into
this TV and even with SVideo in. I got these question for the owner...
Has anyone try to hookup a PC? DVI or SVIDEO?
How is the picture quality (icons) on this TV? Can I really surf the web?
Can I use the PIP to surf the web and watching TV? or use the split screen feature?
Any issue with the burn-in especially with the PC setup?
Should I spend the extra money for the extended warranty?
Is the basic cable good for this set? or do need to go HD?
Should I go with Projection vs DLP vs LCD for this situation?
Thanks in advance.
Garfield2000
post #196 of 819
I use the DVI connection for my HD cable box. Reg cable looks good, but HD is where this unit shines. Don't know about hooking up a PC, but I suspect that burn in would be an issue on this or any other RPTV, especially if the TV screen would look just like the computer monitor with Internet Explorer running. The taskbar at the bottom of the screen would be burnt in fairly quickly, as it never changes.
post #197 of 819
Has anyone tried the i.link yet? I have the 51ws550, and tried it the other night with my Sony Digital 8 camcorder and I'm a little disappointed. I was expecting to be able to see a true digital to digital connection full screen. However, I have an annoying split screen with the digital tuner being on one side and the i.link on the other with no way to get rid of either.
post #198 of 819
Unless you have Gmail, then IT'S ON!!! I've e-mailed for mine!
post #199 of 819
I have to provide ftp to the sender to receive it.
Have you tried the service menu convergence? Do you follow the service menu to do it in Full mode, then copy it to other modes and re-register, or you do convergence for each mode then re-register?
post #200 of 819
Sent you a note last week.
Anyone else get this? If so, please send to dirkbelig@gmail.com. TIA!
post #201 of 819
Everyone,
over in the zenith 318 dvd player thread I posted directions that disables the vertical squeeze when in 1080i and 720p and it was suggested that I post here as well. Now this works for my tube (32hs500)... so let me know if it's cool here as well. In the service menu, the item is JUMP and the default is 1. Flip it to 0. It's in 2170D-3 and the description is "reference pulse jump switch". As with any service menu changes... USE AT YOUR OWN RISK. The PQ is decreases and I never use it, but others use it for video games etc so it fills the whole screen. Cheers,
post #202 of 819
Hi, I am trying to decide between 510 and 550. Looks like more folks are leaning towards 550. But I was told that 510 has built in HDTV receiver, but for 550 you need to buy a separate one. Is that true? With about $200 - $300 dollar difference, is it worth to buy 550?
Please help in deciding.
post #203 of 819
You've got it exactly backwards (as a quick trip to Sony's site to do some basic research would've told you) as it's the 510s that DO NOT have the built-in OTA HDTV tuner and the 550s that DO have the HDTV tuner.
If you plan on getting Voom or the HD versions of DirectTV or Dish network or a HD cable service, get the 510 (though it has a a different - some say inferior - screen design with more glare) because the HD tuner will be redundant. If you live in an area with a decent selection of local stations providing HD and/or you're more about DVD viewing, go for the 550.
Hope this helps.
(Now if someone would be so kind as to send me that service manual, please? Thank you.)
post #204 of 819
Originally posted by jbird04
Everyone,
Anyone else try this yet?
post #205 of 819
I forgot to mention one thing about the vertical squeeze trick. You need to be in 1080i mode for this to work as well. Default in 480p is 0. The bad thing about it is that it vertically stretches widescreen material and you'd have to flip it back for that.
post #206 of 819
Can someone explain the proper way to perform Service Menu Convergence.
I am familiar with the service menu etc, not sure what is needed to perform the convergence however.
post #207 of 819
There is a link posted in this thread toward the beginning that addresses lots of tweaks for these TV's. How to do a service menu convergence is explained in that document.
post #208 of 819
Disclaimer: Use this at your own risk. In no case will I be held liable for injury or damage (consequential or otherwise) resulting from or arising out of alterations you make to your television.
Spoiler
for ws510 series
FUNCTION OF KEYS ON REMOTE CONTROL (in PJE category)
key "1": Changes adjustment item. (Item # moves up)
Marker moves clockwise from center to outside.
(In Fine Adjustment mode)
key "4": Changes adjustment item. (Item # moves down)
Marker moves counter clockwise from outside to center.
key "2": Changes adjustment category.
(Category # moves up)
key "5": Changes adjustment category.
(Category # moves down)
Joystick: Changes data value. (Up or down)
(up, down, right, and then left) to outside.
key "3": Changes adjustment color.
GRN BLU RED
key "6": Displays or changes internal test signals.
crosshatch + external signal
crosshatch + borderline
crosshatch only
dot only off
key "9": Switches adjustment mode.
Coarse adjustment model
Fine adjustment mode
For fine adjustment: (do NTSC Full mode first)
1. Enter the service mode and select PJE category;.
2. Select FDIS item and set the data to 01 so that the data at each
position can be displayed in fine adjustment mode.
3. Press button 6 to display the internal test signal (crosshatch)
4. Press the 9 button on the remote commander and fine
adjustment mode will be active where a green marker appears in
the center of the screen. (In the case of GRN mode)
5. Press down on the joystick, and the marker color will be alternately
switched between green (GRN mode) and white.
6. Press the 1 or 4 button on the remote commander, or use the
joystick to move the marker to the position to be adjusted, where
fine adjustment can be made.
When the marker color is white:
(in this case, fine adjustment is disabled)
Use the joystick to move the marker up, down, left, or right.
When the marker color is green:
(GRN mode)
press "1" : Moves the marker clockwise from the center to the outside.
press "4" : Moves the marker counter clockwise from the outside
to the center.
Fine adjustment can be made on the basis of a marker position
using the joystick to move crosshatches up, down, left or right.
REGISTRATION DATA WRITING
1. After completing each adjustment of green, blue, and red for the NTSC
Full mode press the MUTING + ENTER buttons on the remote
commander to write the registration data to the NVM.
COPYING ALL REGISTRATION DATA TO OTHER MODES
1. Make sure that the adjustment for NTSC Full mode are complete
and the data has already been written.
2. Select the PJE category.
3. Select ALCP item and set the data to 01, and press the
MUTING + ENTER buttons on the remote commander.
4. The data from the NTSC Full mode is copied to all other modes.
Full Screen mode --> Zoom Screen mode
Full Screen mode --> Wide Zoom Screen mode
Full Screen mode --> HD (1080i Full Screen mode)
It is done when ALCP data is changed back to 00.
5. Check in the other modes and adjust as demands.
Be sure to write data in each mode.
re-register Flash Focus (be sure do this in NTSC Full mode)
Once registration in all modes is satisfactory, do the following:
1. Darken the room environment near the set.
2. Enter the monoscope signal to set the NTSC Full mode.
3. Select the PJE category.
4. To automatically store the offset values, press the FLASH FOCUS;
button on the front panel of the set.
(The offset value is now stored)
5. Select ERR item of PJE category.
Confirm ERR is 00.
6. Exit the service mode.
post #209 of 819
Someone forwarded me the manual offered above (why didn't that guy send it?), but it's for the KP-WS510 and I've got a KDP-51WS550. Are the adjustments comparable?
I need to tweak the green decoder and bring down the overscan, but when adjusting the HSIZ and VSIZ settings, it starts bowing across the top and going way out of convergence. How do I set this up w/o making a wreck of things?
post #210 of 819
I haven't figured out how to adjust the overscan very much without getting the same effect. I'll be glad to hear if anyone has a systematic approach.
  Back to Forum: Rear Projection Units
