AVS › AVS Forum › Display Devices › CRT Projectors › What is the best CRT Projector out there
post #1 of 1331
I keep seeing Marquee 8500
What's the best?
I'm gonna keep an eye out in the local classifieds
post #2 of 1331
I love my Marquee 8xxx, but it's not the "best". It uses 8" tubes. Typically, 9" projectors are considered the best.
I think you'll be looking for a VERY, VERY long time if you limit your search for the "BEST" CRT to your local classifieds! :)
Here's my standard good/better/best matrix:
PROJECTORS:
- GOOD: Electrohome ECP3000/3100/4000, Sony VPH-1031/1252/127x, Barco 800/801, Ampro ($500-$1500)
- BETTER: Electrohome Marquee 8000/8500, NEC PG or XG, Barco 808+, Sony 1292, Sony G70, Ampro 3600 ($1000-$5000)
- BEST: Sony G90, Marquee 9500LC ($5000-$15000+)
Input Sources
- NOT SO GOOD: composite VCR
- GOOD: s-video DVD from set top box (480i)
- BETTER: s-video doubled using cheap line doubler ($60-$120), DVD with HD DVI-I scaling ($199)
- BEST: HTPC, HD (720p or 1080i from cable box or $150-$400 HDTV PC card)
- BEYOND: $1000+ videophile components and scalers
Screen
- GOOD: existing wall, bright-white flat/matte paint
- BETTER: wall painted with DIY mix from Screens forum, ScreenGoo, or 4x8 sheet of parkland
- BEST: you can spend $200-$2000+ on commercial screens, see the Screens forum
Cables
- GOOD: S-video
- BETTER: VGA to 5BNC to hook up from HTPC's video card ($15-$150)
- BEST: you can spend lots on cables (if you want to)
Mounting
- GOOD: on a folding table in your basement
- BETTER: Coffee table hush box on your floor
- BEST: Ceiling mounted
- BEYOND: Ceiling mounted with hush box, external venting, finished and receded into the ceiling as much as possible with only the lenses peeking out; or rear projection from an equipment room with a elaborate stage and motorized curtains
HTPC
- GOOD: almost any PC (probably 1GHz+) and it's existing video card, and DVD drive ($29-$129) (total: free-$500)
- BETTER: 2GHz+ CPU, 256Mb+ RAM, ATI Radeon (or nvidia)
- BEST: 3GHz CPU (to play those HD WM9 movies), Radeon with Mike Parker Mods, HDTV card (I love my $159 FusionHDTV-II) for viewing and recording Over-the-Air HiDef TV (aka OTA, i.e. free broadcast).
post #3 of 1331
Sony Vidimagic.
post #4 of 1331
you are the bomb
Which is better the Sony G90 or the Marquee 9500LC
What price should I purchase it for if I find under $5000?
post #5 of 1331
Originally posted by MYoung
Sony Vidimagic.
Mike, that's just wrong.... LOL
Although...with a liquid coupled lense and a couple of tweaks....
Marc
post #6 of 1331
You might as well ask: What tastes better? Apples or Oranges?
$5K is too cheap for either of these. Add about $8-10K and you have a more reasonable price IMHO.
Kal
post #7 of 1331
If you come across one for under $5000, you better pick it up in person.
post #8 of 1331
I'm keeping my eyes open for a $5000 Barco Cine 9 myself....
Mark
post #9 of 1331
As low as the seller is willing to sell it for. If you find G90's for <$5K, buy 2 for me :)
There is a lot more to shopping for CRTs than the digital projectors you're used to. The range of prices is widely variable (2x to 5x price ranges for the same model during the same week is common), the condition of the tubes and chassis, the intentional or non-intentional misleadings from the seller (Thurman is warning you that if a high-end projector deal sounds too good to be true, it probably is), and your configuration/setup of the projector (e.g, just because you buy a G90 and mount it to your ceiling doesn't mean that you're immediately going to be ready to outshoot a DLP).
Oranges. But if you get the right model apple in good condition, they're good too.
post #10 of 1331
Great, List Clarence.I think that portion should be stickied with some more CRT models added.This is going to my favorites folder :)
-Jim
post #11 of 1331
I'd like to see other inputs for the Projector part....
PROJECTORS:
- NOT SO GOOD: (video grade units limited to 480i) Sony Vidimagic/VPH-722/1000/1020/1030/104x (<$300)
- GOOD: (5.5" - 7" tubes) Electrohome ECP3000/3100/4000, Sony VPH-1031/1252/127x, Barco 800/801, Ampro ($500-$1500)
- BETTER: (8" tubes) Electrohome Marquee 8000/8500, NEC PG-6000 (6PG), NEC PG-9000 (9PG) or XG75/85/110/135, Barco 808+, Sony 1292 (9"), Sony G70, Ampro 3600 ($1000-$5000)
- BEST: (9" tubes) Sony G90, Marquee 9500LC ($5000-$15000+)
post #12 of 1331
According to C R T C i n e m a, it's this projector, http://www.c r t c i n e m a.com/ref9.html (remove the spaces), based on an Electrohome 9500.
post #13 of 1331
PROJECTORS:
So If I can find a Marquee 8xxx for $1000 or less or a Marquee 9xxx for $5000 or less then I am hafway there ( the other half being I find out all the used specs and send them to you for approval LOL )
post #14 of 1331
marco-
That's a great, consolidated list. Certainly will help me in building out my HT. Thanks!
post #15 of 1331
THE BEST PROJECTOR IN THE WORLD
THATS EASY . ( THE EBAY SUPER PROJECTOR)
USING A GENUINE 100 PERCENT PLASTIC 6X LENS
WITH A SCREEN SIZE UP TO 200 INCHES
NO TUBES OR LAMPS TO CHANGE
NEVER NEEDS TO BE CONVERGED
AND IF A PROBLEM EVER HAPPENS JUST GO TO
WALL MART AND BUY A NEW 13 INCH PROJECTION TUBE
TO REPLACE THE OLD ONE
AND YOUR READY TO GO FOR ANOTHER 10 YEARS
HOWEVER IF YOUR TO LAZY AND OR STUPID
LIKE I AM TO BUILD THIS ULTIMATE PROJECTION SYSTEM
YOU WILL JUST HAVE TO SETTLE FOR SECOND BEST AND
GO WITH ONE OF THE FOLLOWING PROJECTORS
BARCO CINE 9
SONY G90
SONY 1292
EHOME 9500LC
BARCO 1209
AMPRO 4600
NEC 10PG
XANATOS
post #16 of 1331
does anyone on this forum actually own a Cine9? I never seen the ellusive beast.
Doesnt matter any ways I have my 6X lens! ahah envy me!!
-J
post #17 of 1331
ENVY YOU I DO
BUT BEING TO LAZY TO BUILD A EBAY SUPER SYSTEM
MYSELF
I WANT A RUNCO DTV 1200 WITH IS THE SAME AS THE CINE 9
THREE TIMES I HAVE BEEN CLOSE
BUT THE DEAL FELL APART
THERE WAS A FORTH TIME HAMMERHEAD HAD ONE FOR SELL
AT A GOOD PRICE BUT SOME ONE ELSE BOUGHT IT BEFORE I COULD
I AM JUST GOING TO HAVE TO PUT THE MONEY ASIDE
AND WAIT FOR A DEAL AND STRIKE
IF I AM GOING TO GET ONE
XANATOS
post #18 of 1331
Whats your current CRT?
I'm currently looking for a Reference 8...their great and pretty cheap...A machine blessed by the gods....
post #19 of 1331
sony 1292 with a dvp 5000
the faroudja way to expensive for what it does
i would have been better off with a rock plus
you might as well go all the way and get a reference 9 you will never be happy if you dont
XANATOS
post #20 of 1331
Well I would but I cant afford it now,I'll be happy.. trut me..lol
I was happy with my Barco 600 and ECP4000 and even with an...l...l...LCD! yes I said it! lol My standards fluctuate from time to time, I'm happy with what I can afford.
well my Quadrupler just came here Via Fedex...I'm gonna go fix my Barco G801s now...wish me luck :)
-Jim
post #21 of 1331
LUCK
post #22 of 1331
I would go with the Sony Vidimagic as well. It looks cute like a little digital PJ. (ABOUT THE SAME PICTURE QUALITY TOO...)
post #23 of 1331
post #24 of 1331
I split your "good" category into two by creating a new "reasonable" category. added a few PJ's as well.
PROJECTORS:
- NOT SO GOOD: (video grade units limited to 480i, ES focus) Sony Vidimagic/VPH-722/1000/1020/1030/104x, anything with analog convergence (<$300)
- REASONABLE: (5.5" - 7" tubes, data/graphics grade, ES focus) Electrohome ECP3000/3100/4000, Sony VPH-1031 ($500-$1000)
- GOOD: (7"-8" tubes, data/graphics grade, ES focus) Sony VPH-1252/127x, Barco 800/801, Ampro 2000 ($1000-$1500)
- BETTER: (8" tubes, data/graphics grade, EM focus) Electrohome Marquee 8000/8500, NEC PG-6000 (6PG), NEC PG-9000 (9PG) or XG75/85/110/135, Barco 808/808s/1208, Sony 1292 (9"), Sony G70, Ampro 3600 ($1500-$5000)
- BEST: (9" tubes, graphics grade, EM focus) Sony G90, Marquee 9500LC, Barco 1209 ($8000-$15000+)
There's still many missing, and a lot of it's IMHO!
Kal
post #25 of 1331
how about the VisiOn 0nE?
Oh yeah...how about Selecos..? are they crap? Ge imagers...410 (im thinkin about one...need opinions..lol)
post #26 of 1331
- BEST ON A BUDGET: (9" tubes, graphics grade, EM focus) AmPro 4200, AmPro 4300, AmPro 4600
IMHO!
post #27 of 1331
GE Imagers are same as NEC PGs (good)
Kal: I was tempted to add Barco 1209 earlier but I hear so little about it
EM focus is a good discriminator to separate good from better
I like the "REASONABLE" category because that captures the good $500-$750 starter units which will blow the socks off of a $1299 RPTV that you can buy at BB or CC.
post #28 of 1331
Vision one is simply a rebadged Marquee 9500LC (already on the list).
Kal
post #29 of 1331
Ohhhhh, jeez why cant companies make their own stuff! :( I thought Vidikron was a respectable company..lol
post #30 of 1331
OK, where would a 9" Ampro 4000 ES focus projectors be put on the list? Do the NEC pg's with ultra small 7" tubes really deserve to be where they are?
  Back to Forum: CRT Projectors
This thread is locked
