Originally Posted by SFischer1
Repeating the Question:
When there are NO workers on Sutro tower can some stations be on one set of antennas and others on the other set?
And are they actually doing this?.
Larry, any chance of getting pictures of how they switch antenna sets, or at least a description of the method.
SHF
SHF
I have no idea how they have the main digital and alternate antennas wired in up at Sutro... you'll need to get the answer from someone who has been working up there recently.
BUT... I did see a report this morning on the SF HDTV Yahoo Group that there was an antenna glitch that knocked KCNS and KCSM off the air last night and right now KCNS 38, KBCW 44 and KCSM 60 are all transmitting on the new auxiliary antenna, and will be at least until Sunday. All of the other UHF stations are running on the (old) main DTV antenna. KGO is transmitting with their former analog antenna at the top. So, yes, they can have some stations on one antenna and the others on the other antenna.
This is a good time to check to see how the signals from the new auxiliary antenna come in for you. How well are you getting KCNS 38, KBCW 44 and KCSM 60 today? That's the signal you'll see from all the stations when the crew is working on the tower this Summer.
KGO 7 will, of course, have to use their auxiliary antenna for quite a while, when the crew takes down the Southwest tower leg that they're on. They get a new antenna back at the top, but there will be a time that they won't have a main antenna and will have to transmit from their auxiliary antenna full time.
As for pictures, I no longer have access to the site. My ID card was taken away when I retired. So the only pictures I can get are of the tower itself, and I will be posting pictures of the antenna work as it progresses over the Summer.
Larry
SF
