I was thinking about my tests yesterday with adding attenuation after the preamp and how that affects the setup, especially the system noise figure, which takes into account losses between the preamp and the TV.
It was a cold, wet, and ugly day up here today so I worked on an Excel spreadsheet where I could enter all the parameters to calculate system noise figure and also a graph to see what the affects of adding attenuation after the preamp were.
It's just a small Excel file and you can download it here:
http://images.aa6g.org/System_NF.xls
Enter your parameters in the blue boxes. The green box is the system noise figure. The graph shows the affects of adding attenuation beyond your coax loss, same as increasing the length of coax. The default parameters are the actual numbers for my setup at 700 MHz.
Total Coax Loss is determined form the length of your down lead plus any jumpers. Misc Loss in my case is the loss of the diplexer I use to combine separate VHF & UHF antennas. Splitter loss is entered there. TV Tuner Noise Figure is a guess based on what I've read ATSC tuners should be. If you're using a distribution amp enter the noise figure for it instead of the TV.
I included a couple of tables showing the typical loss of high quality RG-6 and RG-11 coax for VHF and UHF. I also included typical losses for 2 and 4 way splitters.
You can gauge if you have about the right preamp gain by looking at the beginning of the line. If it's quite flat you have more gain than you need. If it's steep then you don't have enough gain. The default example is set about right.
In the default example, adding 30dB of attenuation after the preamp is about the same as putting a 20 dB attenuator ahead of the preamp.
Those other numbers at the top are notes to myself so I can remember what I did sometime in the future.
Chuck
Edit: I improved the spreadsheet by expanding the table showing attenuator settings and the corresponding Signal Margin. Signal Margin (dB) is the amount the signal is above the minimum level at which the TV will lock that station.
Chuck
