Originally Posted by 888CALLFCC
DAP Quote
Most trouble I have is with channel 7. I'm not sure if the problem is multi-path or FM interference. I have added an FM Trap (the FM signals were 43 dB stronger than channel 7), but I don't yet have enough experience with it to know if it helped.
The CM-2001 is a wrong antenna choice ... for San Jose.
I see no cut-size VHF elements, only a rear reflector.
9 elements total .. all cut for UHF.
No elements cut for VHF = Iffy channel 7
Pick a antenna with balanced UHF-VHF gains. Such as the "up-7" antenna models. With copy-cat models made by every major antenna manufacturer.
DAP Quote
Take a second look. That "reflector" as you call it is actually a dipole for VHF. This antenna is rated down to channel 2. That being said, it is effectively a dipole antenna for VHF, very little gain, and almost no directionality. This antenna as a bit of a director, but no reflector for VHF.
They've got a documentary tribute to Alonzo Mourning. Obviously an ESPN piece. Finally after a couple of hours or so they had something like an hour of "encore" coverage of the golf tournament, which was obviously the ESPN presentation just monkeyed up, chopped up. Some guy would hit a button and right in the middle of the show would be a set of commercials. It was horrific. Of course, I despise ESPN in general, and their team covering the tournament is atrocious. The coverage ended at the previously appointed time of 3 PM, I believe. So I got one hour instead of the scheduled 3 hours of coverage. I figure I should complain to someone and bitch about the two missing hours of coverage. I guess I can leave a comment at KGO's website, and I will.
They can make that assumption, but to screw the viewers by flat out shortchanging them in the face of the schedule is sooooo gross!
