We all know that I'm totally whacked out and crazy, so pretty much nothing I do will surprise you, right??????
I previously reported a few interesting tidbits re the PS Audio P300. First, I tried it up in the air on my Dwin 7" CRT, and I really luved what I saw, the best picture I ever had. But this was short lived. Within 4-5 days, I noticed the picture being irregular, better some times, worse some times, and overall I didn't like what was happening to the picture anymore. So I took down the P300 from the projector, and I put my old projector tweaks back up.
Then I used the taken down P300 to feed another P300 into which was plugged a Theta Voyager DVD/LD/CD, DSS, JVC S-VHS VCR - picture and sound was better than ever
(I won't say picture was better than its best moments with the P300 on the CRT projector initially, however). But within about two weeks, I started noticing degradation of picture and sound quality. Conclusion that the P300 (which fed the other one) was running at 240 - 270 watts displayed on front panel, very, very hot, and over time this
degraded the generated AC quality. So I placed this elsewhere.
Today I got my P600!!!! (CHEERS!!!!)
This is my setup:
1. Over at the very left side of the equipment racks, I have one P300 which now has plugged into it two JVC S-VHS 9600 VCRs, an AM-FM tuner and Sony DSS (second receiver in room used for recording off DSS, while I am watching HD or any other programming with other RCA DTC-100 HD DirecTV receiver).
2. Over at very right of equipment racks, I have two P300s. Plugged into one of the P300s are RCA DTC-100, Theta Voyager, Dwin Transcanner & Camelot Dragon (DSS jitter reduction). Plugged into the other P300 is only the Theta Casablanca surround processor.
I have the two P300s on the right plugged into the P600. And tonight, I like what I hear and see. The audio is clearly better defined, more dynamic and "cleaner", and the video does seem a bit brighter and sharper.
Even with all components plugged into the two P300s on the right, the P600 shows use of 300 - 350 watts.
I am ordering a very long power cord so the P300 on the very left can also connect into the P600. This won't up the power usage of the P600 hardly at all, because the connected components barely use any power when not actively used.
I am going to try a 25' extension cord shortly with the Dwin CRT projector, because I've got plenty of power to spare with the P300. I'll let you know. I expect that the P600 won't have any current limit problem like I saw using the P300 with the projector.
Assuming this works, I'll order a long power cord for this purpose. (Woops - I'll take some time on this one, just in case I decide to move up to a 9" CRT that uses a lot more power than the Dwin CRT, but I really don't think I'll even be considering this for at least another two years or so - I just don't wan fan noise, and I already have a great picture, expected to be even better using the P600 with the projector, too).
I was concerned about what I'll call crosstalk (noise backing down power cords of connected components through P300/600 making its way to components connected through other P300/600). But even though this may be technically possible, already I can see a bit and hear a good amount of improvement using the P600 to feed the P300s.
Once again, my initial thoughts. I'll come back and let you know whether over time my observations hold water! But I think they will because, as Stacey Spears has pointed out, the P600 has so way much more heat sink and frame that its almost equivalent to three, not two, P300s.
ALso, I am demoing a PS Audio Lab Cable, currently connected from P600 to wall. Later on, I will substitute a Harmonic Tech cord in its place and I will let you know what I think. I think the Lab Cable retails nearly 180% the retail of the Harmonic Tech cord.
This is my setup:
