mikek
I can't get the changes in the replay network to take.
After I change them to the above numbers the replaytv tries to verify the network and fails. -mk |
WiRNS -server is running right?
Did it output something like "[DNS] Spoofing response of 59 bytes" ?
If your ReplayTV is pointing at WiRNS, maybe WiRNS isn't configured properly?
I had my WiRNS configuration screen (The new 1.0.0 HTML config screen) set for "WiRNS IP: 127.0.0.1" and that was giving me problems with the DNS being accepted in Replay's "Network and Input Settings"
It's now set to be the IP of the PC running WiRNS (I hope this is right, because I've got a different problem indicated in the previous message) -tommy
