AVS › AVS Forum › HDTV › Local HDTV Info and Reception › San Diego, CA - HDTV
San Diego, CA - HDTV - Page 33
post #961 of 1081
On the Channel six morning show they said goodbye to their old studio cameras. They closed by saying that they would start HD broadcast in about a week.
post #962 of 1081
It's about time. I guess the only station that has yet to go HD is XHDTV (XDTV)-my 13/49.
post #963 of 1081
Can someone post some new TSReader HTML data for KNSD? I hear they've added Mobile DTV and want to confirm.
- Trip
post #964 of 1081
- Trip
Here is the KNSD htm. 0x1ff6 (9.46% ~ 1.83 Mbps) Unknown usage, is that it?
knsd2011apr15.zip 1.9453125k . file
post #965 of 1081
Yes, indeed, that is it. Thanks.
- Trip
post #966 of 1081
- Trip
Currently showing NBC+ weather. To view it you need decontv's player.
http://www.mobile-dtv-viewer.com/
post #967 of 1081
Originally Posted by ProjectSHO89 View Post
Keep in mind that, in almost all cases, you cannot combine your OTA signal with the cable internet service on the same cable at the same time....
Why not put the two on separate cables? Run one directly from the CATV cable to the modem and connect the antenna to everything else.
post #968 of 1081
That is what you have to do. The original poster didn't want to do that..
post #969 of 1081
Not much has gone on with the site update wise. I did update the board to MyBB v1.6.3 which fixes some bugs, and it's now fully compatible with IE9. I've also installed Forum Runner for our iDevice and Android users.
If you haven't visted, please check out the San Diego HDTV forum at www.sandiegohdtv.org/forums
post #970 of 1081
AVS Forum uses a version of Forum Runner for their iPhone and Android app, so you know it's good.
post #971 of 1081
Originally Posted by domino92024 View Post
Ya can if you first filter out signals >800MHz and <40MHz.
It is important to understand WHY you can't "share" the same coax for OTA and Cable.
Cable occupies nearly every frequency. Channels below 50 MHz are occupied by cable
modems and cable boxes/DVRs uplinking control/data signals to the local hub.
Channels from about 50 MHz to the cable system max frequency are fully populated
with TV and cable modem downlink data signals:
http://en.wikipedia.org/wiki/North_A...on_frequencies
So when you try to combine your very weak OTA signals onto the Cable Coax, they are
hopelessly buried below the strong cable signal levels. And even if your Cable system
had an unoccupied channel, the very strong intermodulation noise bleeding into that
channel position would still be much stronger than the weak OTA signal.
If you are a "Bare Bones", i.e. "Basic Cable" subscriber, the Cable system's
"Expanded Basic" filter probably only attenuates from about Ch20 to Ch70.
But probably NOT ENOUGH to suppress cable channel leakage on top of your
weak OTA signals...and those pesky out-of-band intermodulation noise products
will still be a problem if they don't also filter out the Digital Channel Tier, which
they probably DID NOT DO if you are an INTERNET only subscriber.
There are also LEGAL and Safety-Of-Flight problems if the strong cable signals were
to leak out via your OTA Antenna. And BTW, 20-30 dB port-to-port isolation in the
combiner is nowhere near enough to drop the cable signal leakage to acceptable levels.
And finally, if you are injecting your OWN RF Video signal onto a Cable Coax,
a Single Channel Injection Filter AND an isolation amplifier are essential to
prevent leakage of those signals back into your neighbor's cable systems.....
post #972 of 1081
A little late to the dance, eh holl_ands?
post #973 of 1081
This stuff should be posted on the San Diego HDTV wiki.
http://www.sandiegohdtv.org/wiki
You login via your sandiegohdtv.org forum username and PW.
post #974 of 1081
Looks like Cox and Time Warner's 4SD stranglehold of Padres baseball is coming to an end. Not for this season, but by the start of the 2012 season. I have a feeling that there could be a Fox Sports San Diego coming. Article courtesy of Dan Hayes of the North County Times.
http://www.nctimes.com/sports/baseba...36e7d1df2.html
In the end, I'll be glad for the people who live the in Padres TV market who live in areas where cable won't serve them and of course myself who would love to ditch Time Warner Cable TV service (and I'm sure others would love to ditch Cox) and switch to DirecTV (I will say though, I am pleased with TWC Road Runner and will continue to keep their high speed internet).
post #975 of 1081
By then Directv will have a sweet RVU enabled HR34 DVR and C30 client that can feed multiple TV's. Some TV's can access it without a box.
post #976 of 1081
Then again, my TWC contract is up in September.
post #977 of 1081
By Don Norcross and Jay Posner
Originally published April 21, 2011 at 8:47 p.m., updated April 22, 2011 at 11:56 p.m.
Channel 4 San Diego probably will not continue to carry Padres baseball games following the 2011 season, station manager Dennis Morgigno said Thursday.
... the primary home of Padres telecasts since 1997, and its exclusive home since 2004, but its contract expires after the current season.
A club source said no deal has been reached with another company to carry the games.
http://www.signonsandiego.com/news/2...es-TV-picture/
post #978 of 1081
XETV SanDiego6 News now in HD. I like the bottom tickler. Its quite large.
post #979 of 1081
That's what she said!
post #980 of 1081
I know this is a very general question, but who do you recommended for HD programming and internet in 92101? I am coming from FL and I use Comcast who I am happy with but they are not available in SD.
post #981 of 1081
HD programming and Internet? Cox/TWC cable (according to location.)
Or, Verizon FiOS if available in your area.
Or, DirecTV for TV, Cox/TWC for Internet only.
post #982 of 1081
I'm pretty sure that downtown SD is Cox Cable, so much better than TWC. AT&T also may be an option with U-verse for TV and Internet, as well as Dish. Verizon FiOS is not yet available in San Diego.
post #983 of 1081
But last I saw, AT&T's HD was garbage. And their Internet was slow compared to Cox.
Last I knew, FiOS didn't come any further south than Temecula. My sister has FiOS. She loves it. She complains to me about everything, but she hasn't said one bad thing about FiOS.
post #984 of 1081
Yesterday, all three of my SA8300HD DVRs would display the Menu requesting entry of the
Parental Blocking PIN number, which finally revealed the program.
I had to do this every time I changed channels. The Guide & Info displays only said "LOADING".
Today, I noticed a very subtle change in the Guide/Info displays...perhaps larger/sharper font???
Yup, I now have the new RED CLOUD version:
PTV: v.6.14.99.sp dated 26Jun2009
Res: 3.00-15-ptv (Red Cloud) dtg 2Mar2011
DAM: Res: 3.00-15-ptv (Red Cloud) dtg 2Mar2011
Riot: 1.00.3.797
I also noticed new diagnostic menus for Remote DVR (Whole Home DVR) and RIOT,
which appears to have something to do with interactive product browsing (and ordering?):
http://fourthwallmedia.blogspot.com/...long-tail.html
http://fourthwallmedia.tv/PressRelea...2-0809d51d2dd8
http://www.alanquayle.com/blog/2009/...ru2way-oc.html
http://en.wikipedia.org/wiki/Interactive_television
post #985 of 1081
MDN v3.0.0-15 is pretty good, but no you can't have WHDVR on the legacy boxes.
I've heard reports of a smaller buffer with MDN v3.0.
post #986 of 1081
I've already lost a couple of Series Recordings and even the Ellen DeGeneris Show
I manually enabled about an hour prior to when it should have recorded (while I
was busy watching an old recording)....
SO I'M CAREFULLY CHECKING EACH AND EVERY RECORDING!!!!
BTW: Program information is displayed in three different formats:
1) SHORT, as shown when you press the GUIDE button,
2) MEDIUM, as shown when you then press the INFO button and
3) LONG, as shown when you access via the SEARCH feature (adds actor names, et. al.).
The LONG form has not yet been populated with data, which might explain the loss of
series recordings.....rebooting didn't help.....nor searching forward a week in the Guide...
Earlier today, I noticed that they had deleted the "NEW" program indicator from the
SHORT form....that meant I had to cycle the INFO button ON/OFF as I trolled through
the guide (boo, hiss)......but now I see that it has been resurrected.....hourray.....
We used to be able to mark a future recording to NEVER DELETE, but when I go
through that process now, it SEEMS to go through the menu sequence OK, but it
doesn't actually mark the recording with the NEVER DELETE icon as it did before.....
(And it's too early to know if this process REALLY works...)
I was playing back a recording (the News) from the beginning while it was still being recorded,
watched enough and tried to STOP/DELETE.....it got confused about half-way through, forcing
me to go back and manually delete the partial recording....buggy, buggy, buggy.....
post #987 of 1081
Going forward in the Guide successfully populated the SHORT (Info) and MEDIUM (Guide)
displays....but did NOT result in populating ANY of the LONG (Search) displays....I got ZIP!!!!
Several Series recordings successfully recorded last night without any help, but I also noticed
that a few had been dropped from my Series recording list....so, one more thing to check.....
It also successfully recorded several programs that I had "manually" selected via the Guide.
Last night the "NEW" designator that earlier was displayed in the MEDIUM (Guide) display
had (again) completely gone away.....the plethora of extra buttton pressing is very annoying....
I intentionally tried to STOP/DELETE several recordings while watching them "live"....no problem.
But menu is VERY CONFUSING: WAIT while it finishes (what???) or SELECT to continue.....
Either way seemed to work, although I fail to see why I would ever want to WAIT for 30-seconds
or so for the DVR to do some sort of house-cleaning task....what possible task could it be
doing that would be of any interest to the viewer that would result in some ADDITIONAL menu????
I already selected DELETE....and confirmed with a YES....just DO IT already...no more buttons!!!!
I suppose it is possible that after deleting the current program, a previously conflicted program can
NOW be recorded. If so, there is no need to WAIT for 30-seconds while searching for a possible
conflict resolution before informing the viewer (which should take less than a second anyway....the
table of previously detected conflicts already exists and is very, very short).
And if this WAIT is there in the rare possibility that the viewer might have to chose between more than
one conflicted program, why not pop-up the new menu 30-seconds AFTER closing the DELETE menu???
[BTW: An equivalent menu was in the previous version....WAIT while it searched for conflicts....why????]
Yesterday morning, when I first started using the new version, it actually ALLOWED me to use the
Guide display to enable a THIRD, overlapping recording.....it failed to detect the conflict.
BTW: It was a movie that started before and ran after a half-hour time slot that I ALREADY had
two series recordings, as displayed in red in the Guide.
I tried several times to enable more than two recordings in the SAME time period, but each time it
(correctly) displayed the conflict resolution menu...but I'll be checking some additional variations...
esp. with partial overlaps......
post #988 of 1081
As of this morning, the "SEARCH" database was finally populated, so I'm hoping the
Guide problems I saw yesterday will settle out today....or perhaps in a few days...
post #989 of 1081
NBC California Nonstop has replaced the weather plus channel (39.2). Also showing on the mobile channel.
http://en.wikipedia.org/wiki/NBC_California_Nonstop
post #990 of 1081
Site (sandiegohdtv.org) is down due to a datacenter outage.
