Right. If it ain't broke, don't fix it.
I have seen those Scientific Atlanta boxes. They're crap.
Time Warner tried to backdoor one of those one me when I had three HD boxes brought into the house. LOL. Two awesome Pioneer units with DVI output and then...that thing?
You couldn't even change aspect ratio on it. It only went into 1080i, supposedly, nothing else. So, you always had, sometimes, black bars around the entire picture, zero flexibility, and just a cheap product.
I had Time Warner swap that out for another Pioneer box in person at the TW office the next day. If you have garbage like that, get it out of there and demand a DVI output box from your cable company. Usually, it has to be a better product if it has one of those on it.
I'd still be willing to bet that at least some of these problems in this thread have nothing to do with the TV itself. In fact, I'd bet most of them. Guranteed.
The best way to prove it, I suppose, would be to do one of two things:
1.) Plug the coax cable from the wall straight to the TV. Find an HD channel. Test it that way. Independent of any box.
2.) Find some kind of other HD source (DVI output DVD player or something...) to test.
If the problem is really with the TV, I have to believe that you would see something, regardless of input. There would be some kind of constant side effect.
Not saying it can't be the TV, but I'd really go to the ends of the Earth to troubleshoot it first. ;)
