AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Very Fresh Firmware List for Panasonic! (RP91 and XP unit discoveries!!)
Very Fresh Firmware List for Panasonic! (RP91 and XP unit discoveries!!) - Page 8
post #211 of 1154
Zoro, I'm pretty sure you need the Panasonic Service disc #2 to do the region free, and I 99.99% sure the RP91 would be unable to do PAL->NTSC without a hardware mod, and even that is iffy.
post #212 of 1154
Well, I've tried, three separate discs now since the original on my CP67... one burned with a better quality burner and media with Blindwrite and another burned on an eMac from a dmg file. All of them load to 3 0's on the player then the display flickers and I see all 5 0's and the Panasonic DVD logo background. Any attempt to play the upgrade discs fails. The player still seems to play all my other media fine, but the firmware remains 032.
Oh well, no loss, no gain, I guess.
post #213 of 1154
I think, I concur with your prob Sam!!
post #214 of 1154
Well, this has been quite a frenzy of activity in our little community! It is always interesting to observe the effect finding ways to improve Home Theater has on fanatics .
Sango - nice work and great help!!!!
I am a bit surprised that no one has asked this particular question before. Before I stick the disc into my Denon 1600, I want to make sure I burned it and got everything I need. My CD shows 94.3 MB and has the following files:
- A VIDEO_TS folder
- A file named "DVPPUPDT.FRM"
-A folder titled "MEI_DVDP" and inside are 2 files titled:
- MDP010_FRM
- MDP010_1.PGC
Is this the correct mix, or am I missing something?
There have been a few folks weigh in with the update on the 1600. Are there anymore and do we actually know what the firmware update does?
post #215 of 1154
Hi everybody
I have my XP30 and RV32 upgraded couple days ago (thanks to Sango and Tyler helped). I already post the improvements, "tricks" that the units would be able to do after the upgraded. Well, today I just found out that the upgraded units would also play DVD+R....you all know that Panny's unit dont play DVD+R....but with the upgrade..they will play anything...wow...thank you everybody and keep testing...
post #216 of 1154
Hi Ray:
Yes the files are correct, assuming you mean the video folder also has files as well. The improvements on the 1600 is about the same as all the other units are experiencing which has been mentioned on the thread before with the "stunts!!".
Sango
post #217 of 1154
Just did the upgrade to my XP30. Haven't had a chance to view a DVD though...
Thanks to everyone who contributed.
I had a quick question (and forgive me if I missed this during my two trips through this thread)... Has anyone noticed if the layer change time has improved at all? Just curious...
post #218 of 1154
Hmm interesting question. I haven't tested that out myself. Maybe people got a movie to watch and you guys see =)
post #219 of 1154
Sango:
I'll be sure to post my impressions (including the layer change) once I take a test run with v. 302
I'm interested to see if my relatively newbie home theater eyes will notice any improvements.
post #220 of 1154
i've tried burning a video on dvd+r and it wouldn't play on my denon 1600, anyone else try the 1600 for dvd+r?
post #221 of 1154
I did +R, +RW, both worked fine!! in nut shell, it played almost all formats
post #222 of 1154
interesting, what type of +r discs are you using. btw for the mac users that can't deal with the original files in the .rar, here's a link to an uncompressed iso, and a compressed iso (zipped with winzip)
uncompressed iso file 96 megs
compressed iso this was compressed with winzip, if a mac can deal with winzipped file this one is smaller 50megs. just double click on the .exe and it will extract, this one includes the instructions.
Use what cd burning software you have that burns iso files, these files will work with a PC as well, for anyone who had problems dealing with blindwrite, try nero work great.
blair
post #223 of 1154
Thanks to all, particularly Sango......I was successfully able to update the firmware version of my XP30
Fo my ease, i had collected the various instructions etc posted by different people in this thread to understand the process (very simple process on the hindsight )
I am pasting all the info in this post below, so others may be able to get it all in one place:
BTW- for those xp-30 and xp-50 owners the way to check your firmware version: Press pause and open ON the UNIT PLAYER buttons simultaneously and hold down, then press 7 on the remote. The LAST 3 digits displayed on the unit LCD screen is your firmware version. This may work for RP82 and other Panny DVD players - others have to confirm that.
The .rar file is compressed. You have to unzip it and then burn the contents. Sango suggested Blindwrite to burn it. I used it and it worked great.
You need WinRar to extract the rar files.
Use Blindwrite v4.57 to burn the image.
- use writing method DAO Pw (best writing method)
use winrar to unzip it. then use blindwrite to burn it. When it is unzipped the files are coded as blindwrite files - at least they were for me. Then you open blindwrite search the directory where you unzipped to and it will detect the files. Note - it will only show 1 of the 3 files that you unzipped but as long as all 3 files are in the same directory selecting only the 1 file is fine. Then burn.
Correct you must use Blindwrite 4.57. Blindwrite is one of the best powerful recording tools to use(Alcohol 120% is just as equal). CD-Creator is like nothing compared to Blindwrite, same goes to Nero if you want to do perfect copies (which also include protections).
Settings for Blindread:
Put a check in this checkbox: Extract subcodes(if your reader allows it) <- This is how youm make perfect copies of CDs, because of this!!
Settings for Blindwrite:
Writing mode: DAO Pw
Speed: *Lowest as possibe
As I've mentioned in my thread, use Blindwrite 4.57. The reason is because in the 5, the advanced features which I'm talking about are missing so this is why I specifically mentioned the particular version.
Nero can't read BW format, except the the other way is true. Nero can most likely copy if it I made the image using Nero but I don't trust it because it doesn't copy subcodes. It will copy but there isn't any guarentee that it's copied exactly perfectly like the original.
An example would be copying some disc which has a some protection which looks for something at a certain location on the disc. Without subcodes, you can copy fine. However, when it comes to trying to test the disc, you'll end up with a disc which doesn't work and i'll give an error message or saids, please insert the disc etc.... With subcodes, none of that.
I found two very good tuitorials reguarding the read/write methods using BW 4.57. They are very useful. I remember the BW site originally had it and it's gone.
I suggest that users should read very throrougly through them to fully understand understand Blindwrite and it's features why it makes it a very powerful recording tool.
Link 1 http://users.pandora.be/soulmaniacs/...tml#section_11
Link 2 http://www.cdfreaks.com/article/90/9
Note: I aimed the two links intentionally to the writing page to get that question out of the way but you should read from the very beginning afterwards.
This is why in the post, use Blindread - read subcodes and Blindwrite - DAO Pw. Both of these in combination will be the key pointers in making a pefect 1:1 copy. It does mentioned about the SAO mode thing but it's very technical which I don't understand so it should be fine with what I mentioned above.
For people having problem with Blindwrite 4.57, like myself (my LiteOn CD-RW writer was not recognized by Blindwrite 4.57), use version 5 should be fine, at least for the RP82/XP30 firmware part anyway. Because Sango made the file in version 4 format, be sure to select version 4 format when you are looking for the file in your directory.
It has come to my attention that several users are not experiencing the completed screen when the firmware is done updating as it simply displays a black screen after restarting itself. They begin to worry that their unit is gone which insn't true - the final complete screen seems to have glitched out. I didn't experience the issue with my RP82 or 56 thou.
Another issue is which is occuring is being unable to play the player's own region.
I suggest all owners who upgraded their firmware to perform the reset sequence if they gotten the completed screen or not to eliminate issues which may come up.
Simply take out the firmware disc and power the unit off and on again.
Perform the following:
On the unit
- hold PAUSE + BWD-SKIP + OPEN for about 3 seconds
The display will display initialization
- when initialization is being displayed, let go of PAUSE and press STOP while holding the other two buttons.
The display will then display reset.
This will completely reset the unit and it's back to normal =)
post #224 of 1154
Hello to everyone, and thank you to Sango for providing the firmware update for my RP-91. It looks like everything went well, I checked to see if the correct version is installed, and it is (262). However, I am experiencing the "incorrect region" problem and can't play any DVDs anymore. I tried to use the "reset" method you showed in the following manner:
- Power on with no disc inserted
- Hold down Bwd Skip and Pause while pressing Open
The tv screen flickers and then displays "initialized" and the DVD player screen says "INITIALIZE"
- I then release Open and Press Stop
But, I don't get a "Reset" message; the player just seems to know that I pressed Stop.
Then I tried to play several DVDs, still, nothing. I even tried to unplug the power cable.
Did I do something wrong?
I've owned my RP-91 ever since it first was released back in mid 2001 and have never had trouble with it until I just now updated the firmware.
If anyone can offer any assistance, I would be in your debt. It would be a shame to junk a player that I spent over 500 bucks on!
post #225 of 1154
well considering the trouble some may be having understanding blindwrite, that the reason i made .iso files from the disc. just download those and burn and go. (-:
post #226 of 1154
The reset procedure calls for releasing PAUSE and pressing STOP. Try that instead.
post #227 of 1154
Man, don't I feel dumb now. Thanks :-) You were right, I was misreading...it worked!
post #228 of 1154
No problem. I only wish I could figure out what happened with my player (cp67)
The update ran through fine (but I didn't get a "completed" screen), I performed the reset, but my version remains 032. It still works as well as before, anyway.
post #229 of 1154
I did not get a completed screen either. I figured out the reason. My XP30 was connected to infocus X1 through component-VGA and progressive setting was on. After the update the dvd player went back to default non-progressive mode. X1 does not allow interlaced signal through component-VGA connection. I would have gotten the completed screen if the XP30 were connected to X1 through component-svideo (interlaced mode).
post #230 of 1154
I'm connected to my 46" Sony through component, but it allows interlaced... so I still don't know.
The weird thing is that now the player won't recognise the update disk.
post #231 of 1154
Thanks to Sango and all here. A special nod to Nick who provided me with a local copy.
Did the reset and did not notice the word reset at the end, just No Disk. All seems fine.
Only difference I've noticed so far is faster navigation. 236 to 262
E
post #232 of 1154
Took a long time to DL for me, too. Didn't help that with just 5 meg to go AOL friggin' crashed for me. AOL. Joke. Restarted the download with IE and went to bed!
Anyway, for MAC USERS downloading the compressed file: It has an .exe extension. If it won't self-expand when double-clicked, just change the file extension to .zip and you should be all set if you have a zip decompression tool installed.
post #233 of 1154
Ok, Mac people:
WHAT should this CD be burned as? Got the files extracted fine it seems, with "firmware instructions.txt," "iso.txt" ("use your cd burning software to create a cd from this .iso image."... well, ok, I did that!) and the "rp82v302.iso" file.
I've tried burning in Toast 5 as ISO, disk image... my RP-56 won't read it. (I'm doing my RP-56 as a test *before* I do my XP-30. Just to be safe...)
I'm really *not* an idiot! Suggestions?
post #234 of 1154
Have I missed anything here guys ? Why do I need to do the reset after the firmware update ? Isnt that to go back to original firmware ?
I havent reset the DVD player after the update, everything seems to work fine. Why is the reset done ?
Thx
post #235 of 1154
It resets the settings, not the firmware. Some people have been losing their region settings after the update.
post #236 of 1154
Well, I created my update disk, two ways:
1) Downloaded the RAR file with the Blindwrite Image (three files), converted it to ISO using MagicISO, burned to disc using EasyCD Creator 5
2) Downloaded vtb2's zip compressed ISO, extracted it and burned it with EasyCD Creator 5.
Although the iso's were of slightly different size, the files they created were identical in size.:
In Root:
Dvdpupdt.frm 32,800kb
In Mei_dvdp:
Mdp010_1.frm 59,394kb
Mdp010_1.pg 1kb
In Video_ts:
Video_ts.bup 16kb
Video_ts.ifo 16kb
Video_ts.vob 3588kb
Vts_01_0.bup 12kb
Vts_01_0.ifo 12kb
Vts_01_1.vob 234kb
It'll be a few days before I burn them -- my TV is on the fritz -- but it is nice to see I get the same results from two different copies of the firmware.
Sango,
Maybe I missed this, but do you know how this effects the Service Disk 2 macrovision and region hacks? Do I just go ahead with the firmware update and then reapply the hacks?
Joe
post #237 of 1154
Hi Dr Joe:
Yes, you have to reapply the SVC Disc 2 hack because it's gone after the update. Then you are home free once again =)
Sango
post #238 of 1154
Now that I have a pair of xp30's, I also took the plunge and did one update from a disk burned from the iso, thanks to Vtb2 and everyone else for hosting and instructions. Went from 268 to 302, nary a hitch. So far, all I have noticed is a much faster response time on menu and scene access, and commands in general. I plan to A/B the units on my X1 PJ when I get a chance, to see what differences in PQ I can discern. At the same time, I also have a brand-new "official" Panasonic recovery disk on the way one of these days, and if it ever arrives it will be interesting to see if the firmware contained on that is the same version as this one. Some of the file creation dates on the version courtesy of Sango read July 15, 2003, so it is possible that there are further updates. Will report back when/if I have info.
post #239 of 1154
Philo...
See if there is any difference in the layer change lag too. Thanks!
Nothing ever beats a good head-to-head comparison
post #240 of 1154
Will be happy to do this also. Anybody have a favorite layer change chapter/time location they want me to try? I own a few of the "usual suspects", Nemo, LOTR I & II, etc.
  Back to Forum: DVD Players (Standard Def)
