Originally Posted by
300ohm
Yeah, my Sansonic FT300A bars take time to respond to changes too. I imagine youll post a similiar comparison to it later too.
300ohm
Your comparison analysis with the Apex was very useful, thanks again. Deep down, I always thought these cheap CECBs could be sensitive, down and dirty tools to use.
IIRC, you also have the Sansonic. Can we expect another comparison analysis soon, heh ? (no pressure)
Here is my comparison of the Apex DT502 vs the Sansonic FT300A when used as a signal level/BER meter, first in a strong signal area. The signal level readings in dBmV were made with a Sadelco DisplayMax 800 and a 719E SLM (Q=quality, S=strength):
Code:
attenuator Apex Sansonic DM800 719E Equiv
dB Q% S% Q% S% dBmV dBmV dBm
0 100 84 100 100 +9.9 +9.0 -39.8
3 100 84 100 100 +6.5 +6.1 -42.7
6 100 83 100 100 +4.2 +3.1 -45.7
9 100 83 100 100 +1.5 0.0 -48.8
12 100 80 100 100 -1.4 -3.0 -51.8
15 100 76 100 100 -5.2 -6.0 -54.8
18 100 72 100 100 -8.5 -9.3 -58.1
21 100 68 100 91 -10.9 -12.1 -60.9
24 100 64 100 80 -13.1 -15.0 -63.8
27 100 57 100 70 -15.7 -18.3 -67.1
30 100 51 24 60 -18.5 -22.0 -70.8
33 100 46 8 40 Ur -25.2 -74.0
36 100 41 4 34 -29 -77.8
39 95 37 dropout -35 -83.8
42 79 30
45 35 0
48 dropout
And then in a weak signal area:
Code:
0 100 55 100 100 -18.1 -21.0 -69.8
3 100 50 94 95 Ur -25 -73.8
6 100 43 100 83 -29 -77.8
9 92 34 38 70 -33 -81.8
12 57 26 23 60 -36 -84.8
15 21 0 7 56 -39 -87.8
18 dropout dropout
Note: The initial signal level readings are a little lower than last time because I needed to use a 4-way splitter instead of a 2-way splitter to feed 4 pieces of equipment. Because OTA signal levels are constantly changing, the attenuator settings don't exactly match the signal level meter readings, but this doesn't invalidate the general trend of readings.
Conclusions: The Apex box gives a wider range of readings than the Sansonic, and these readings are more consistent in that they are repeatable when given the same signal again. The Apex needs an inverter to run on battery power, which was necessary because I had to move to other test sites with my car because my CM4221 antenna at home is pointed across a well-traveled road which constantly changes the signal bar readings.
The Sansonic box works just a well as the Apex as a DTV converter box and it can run on battery power, but my main concern is its usefulness as a measurement tool. Its readings take a long time to settle (which I could live with), but they are not consistent from time-to-time which puts its accuracy in question. I can't recommend the Sansonic as a measurement tool. My results with the Sansonic confirm what the NAB-MSTV Converter Box Report says about it in this quote (they call it #7):
One unit (#7) even provided two indicators, one for signal strength and one for signal quality. This method is actually one of the best ways for the viewer to understand what is happening with the incoming DTV signal since it immediately indicates whether problem reception is due to broadband signal fading or severe dynamic multipath. However, during the lab testing experience, while the signal strength meter worked well, this particular signal quality meter (in unit #7) jumped around between large and small numbers and was not very stable. Nevertheless, this dual meter approach is a good idea if implemented properly.
Their report is here:
http://www.nabfastroad.org/NAB-STV%2...y-report1.html
Click on Digital Converter Box Report which should take you to:
http://www.nabfastroad.org/NAB-STV%2...report.doc.pdf
The quote is on p22 of 53 of the pdf, which is p5 of 36 of the LABORATORY TEST REPORT under Signal Quality Indicator.
Edit: Added equivalent dBm values for 719E dBmV figures using conversion factor of -48.8 for people used to tvfool signal power values and to compare with NTIA sensitivity spec of -83.0 dBm for CECBs. The dBmV figures for the 719E are less accurate below -30 dBmV because the meter scale is crowded at that end. When using a very weak signal for comparisons, I add a preamp between the splitter and the SLM. Since it is not in line with the tuners its noise figure does not affect them:
http://www.avsforum.com/avs-vb/showp...ostcount=10649
Update: For some strange reason the Apex DT502 has trouble with ION network stations. I tried 3 different units. Also, the Apex does not allow you to add a channel after scan.
