ctdish wrote:
"I am not sure what a CM1220 antenna looks like. Satellite dishes are deep for a UHF antenna and probably should be feed with a fairly low gain UHF antenna perhaps one with two bowties and a reflector. Also the beamwidth will be very small in both horizontal and vertical planes so aiming will be very critical in direction and in vertical elevation. You might need to tweak the tilt angle after it is mounted."
Hi ctdish,
I mixed up the antenna part number, I am using the CM-4220HD which is a 2 bowtie antenna, similar to what the old 4251 used. I think you are right about the tilt. I found it to be quite sensitive while testing on the ground. I will kick it up a few degrees when I reinstall it.
Do you know of anyone doing this?
Mike
Hi ctdish,
Mike
