Originally Posted by
gbynum
He said "condo". If it is really a condominium ownership, at least as defined in North and South Carolina, the outside of the unit belongs to the association, the inside to the "owner". That is why, when they want to be real jerks, even the railings are not usable and a weighted base is required.
"Condominium" is not a type of housing or building, it's a legal instrument to describe communal property. Apartments, townhomes, carriage homes, and even single-family detached homes can all be condos.
When condos are built, the Land Surveyor of record will come in before the drywall is installed and measure the airspace of the unit, stud-to-stud. That airspace, including the drywall and the flooring, is what the homeowner owns in full. Everything else is communal, and the key point for antennas is "exclusive use" versus "limited common element".
There are some townhouse subdivisions where the homeowner owns the whole thing- land, building, and everything else-but it has to be defined that way during the planning stages.
To find out how your property is defined, check the land survey that you got at closing. There will be a text legal description and a drawing that represents the space that is fully owned, and the communal spaces that are partially owned. There can be a lot of gray areas, especially in balconies and patios, but a good condo survey will define those areas clearly.
