Originally Posted by Mister B
Still I get occasional pixelation on KCOS and KVIA (both the RF7 or RF17 versions). The signal quality and SNR figure is constantly on the move for these channels although the SNR does not fall below about 21 at any time. I have read that fluctuating SNR's may be a sign of multipath reception, but the Juarez analogs do not show hardly any "ghost" at all.
I looked at your TVFool results and your stations are close, LOS and very strong. Are you looking through trees? If you have true LOS to the transmitters it's essentially impossible to have the SNRs jump around. They should all be 30 dB plus. The only time I've seen this sort of behavior is when trees were messing up the signal.
I have heard that the SNR is determined by the amp and hope that a very high quality amp such as one of the Kitztech's would help.
Yes, the system noise figure is determined by the first amplifier. It's possible to approach the noise figure of the preamp if all the losses after the preamp plus about 8 dB is equal to or less than the preamp gain. There's a formula to calculate overall noise figure.
That said, it's no surprise that the HDP 269 didn't do anything. Signal strength isn't your problem.
I'm not sure I would call the Kitztech a "high quality" amplifier. It has a very low noise figure but it achieves that by not using any input filtering. Most other preamps use input filtering to reduce the chances for unwanted signals to overload the preamp. Filters are not zero insertion loss. You would need to carefully evaluate your situation before using the Kitztech.
I recently replaced a Winegard AP8700 with a Kitztech on my VHF antennas. The 8700 was a bit low on gain in my situation. I live in a rural area with no strong high VHF stations or FM stations or other transmitters below 174 MHz. I felt I could get away with a preamp with no filters other than the filtering affect of the antennas themselves. Between the higher gain and the lower noise figure of the Kitztech, I calculated that I picked up at least 3 dB in SNR. The result was that my weakest station (CH 7 110 miles distant) went from about 75% reception to 90% reception, an improvement but no miracle. No change was seen on any of my stronger stations.
Chuck
